bike hot or not?
2005 EC200 with Flatland guards, LTR impeller. One rad was tweaked a little before the brace but not bad.
I'm dual-sporting the bike to the trails and noticed more coolant in the overflow bottle. I don't see any coolant on the ground. The motor seems to be at normal operating temps. I can touch the motor so it can't be that hot. Doesn't smell hot. I do ride one gear higher to keep the noise down. I replace the water pump seal last year and added coolant. Maybe I need to get that water pump spinning more. Maybe I added to much coolant. Maybe the thermostat is bad. I'm not sure on the carb settings...so don't ask. Should I be worried?
2005 YZ 250F |
Check the level of the water in the rad's it sounds like it's high and just pushing water out as it expands (gets upto notmal temperature)
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
Skidad |
LOL. I meant rad cap.
2005 YZ 250F |
A bad cap will make the coolant come out of the radiator vent hose.
The overflow bottle is tied into the radiator top tanks. You can always put one of those temperature sensitive strips on you radiator tank. Will give an idea of how hot your motor is running. |
Your probably fine. I always go to a 1.4 bar cap from the stock 1.2, fill the rads to 10mm over the fins and ditch the expansion tank. Never a problem.
Thread Tools | |
Display Modes | |
Getting trials bike clutch feel on an enduro bike? | SpeedyManiac | Enduro Chassis & Body | 3 | 12-01-2010 02:11 PM |
Lugging the bike and stalling - jetting, technique, wrong bike? | stay_upright | Riding Techniques & Training | 21 | 04-18-2009 05:23 AM |
