Old 08-13-2018, 07:20 PM
Originally Posted by Desert Silver View Post
Latest and greatest problem. The damn bolts holding the exhaust manifold won't loosen even with an impact driver! The manifold is hitting the frame and blocking the cylinder from being removed. That bike is bound and determined to make me remove the engine. Hoping heat will loosen the bolts up. Anybody have a metal inner case gasket on their engine?
I pulled the cylinder off my 15 without taking the exhaust spigot off. Just pull it up off the studs and then twist it to the side a little and she pops right off
Old 08-19-2018, 02:14 PM
Desert Silver Desert Silver is offline
Ended up doing the same thing but didn't want to have to remove the radiators. Guess I'm spoiled by my old 91 KTM. Even the 04 KTM 300 I worked on was a pita!
Old 08-20-2018, 02:42 PM
Messaged RK Tech to ask if the their head mod will work on a 2015 300 Sat. and not a peep so far. My son wants more power without losing bottom end and I feel that head work is the only way. All they listed was the 2018 and 2019.
Old 08-20-2018, 04:58 PM
john r b's Avatar
john r b john r b is offline
Most likely very similar.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 08-22-2018, 02:11 PM
What piston is Gas Gas owners using in their 300's? Checked Wosiner and Wiesco and neither of them list a piston for 2015 300. I use forged pistons when ever possible as I feel they are a much stronger piston. If the cylinder has S3 21113 047 # stamped in the base surface is that a stock cylinder part # or one from S3?
Old 08-22-2018, 06:54 PM
john r b's Avatar
S3 makes the cylinder .
'12 XC 200 TTX Sold
Old 08-23-2018, 07:51 AM
I just put a weisco piston in my 15 300. Got it from Halls Cycles
Old 08-23-2018, 02:53 PM
john r b's Avatar
Chris, how was the tko??
'12 XC 200 TTX Sold
Old 08-23-2018, 02:56 PM
Is that the Pro X one? wiesco lists a forged piston for the Gas Gas 300 ATV but only list a Pro X cast piston for the EC300
Old 08-23-2018, 06:16 PM
ATV should be the same motor.
2012 and 2011 ec300e Phaeton Used Bikes 0 10-04-2017 10:08 AM
2011 EC300e part out Mick Parts 35 03-16-2017 07:00 PM
First Ride on '15 EC300E celester Enduro Intake/Carburetion - 2 stroke 2 10-08-2016 04:48 PM
2011 EC300E maiden voyage Bobt250 General Discussions & Announcements 24 01-06-2011 01:33 PM
