Question about clutch bolt - reverse thread?
Backstory: I went to kick the old girl ('14 XC300R) the other day and broke the shaft that the kickstart lever attaches to. GasGas sent me a new one so good on them for doing the right thing!
Now I'm trying to put it on. I have removed the clutch cover and taken out the clutch pack. It looks to me like I need to take off the whole clutch basket to be able to remove/replace the kickstart shaft as it is attached to a gear that sits behind the clutch basket (you can see the broken shaft in the upper left of the picture). That big 30mm clutch bolt in the middle of the attached photograph is the one I'm trying to get off. It has 2 tabs (like a counter sprocket) and I have bent them flat. I'm having a bear of a time trying to get that bolt off, and now I'm wondering if I'm going the wrong direction. Anyone know if it is a reverse threaded nut? I had to take the rear brake pedal off to get the clutch cover off, so I can't use that to stop the rear wheel from turning as I wrench on that clutch bolt. Maybe I need to put it back on temporarily to hold the rear wheel/transmission in place? Thanks for any insight anyone can offer.
Slade '14 GG XC300R - County Cycle Woods Weapon #63 |
The wooden handle of a hammer in the rear spokes seems to do the trick.
Thanks desert - I was worried about bending spokes. You don't think that is a risk?
And do you happen to know if that bolt is a reverse threaded nut?
The clutch basket nut is normal right hand thread.
I use an impact wrench to remove mine. Little drama. |
Never had a problem. Saw that trick on the Rekluse web site.
Impact works for me. Bit of heat if they've used loctite. Lefty loosey.
Copper penny works as well....between primary gear and clutch ring gear.
Impact works great,very little force needed.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
impact works great - even if you think its a reverse thread. Ask me how I know... facepalm. Luckily it a new nut was all I needed.
-Josh 2009 EC300 Six Days |
To Home Depot we go...
Just went and picked up an air impact wrench and a propane torch from Home Depot.
Thanks for the suggestions you guys.
Will a KTM clutch hose fit the banjo bolt on my GG slave cylinder? | bondo | Enduro Chassis & Body | 7 | 12-11-2014 12:53 PM |
REverse Threads | PEB | Enduro Engine - 2 stroke | 5 | 10-21-2011 07:49 PM |
Today's powervalve thread - loose bolt screws race | motogroove | Enduro Engine - 2 stroke | 3 | 07-29-2011 04:33 PM |
reverse?? | 2stroker | Enduro Engine - 2 stroke | 1 | 11-04-2008 07:09 PM |
Reverse for 05 model??? | gateman | Other GasGas Bikes/Quads | 3 | 12-19-2006 10:02 PM |
