Old 10-20-2013, 09:53 PM
forgiven forgiven is offline
Default gg250f loss of power question
OK here is the deal
I have a 2011 GasGas 250f which is an enduro with a 2006 wr250f motor. It doesn't have a grey wire or the other restriction stuff. I bought it used and seemed to be low on power. I put an 06yz250f piston in and no change, and the old one was fine, put in yz exhaust cam very little change. Megabomb header and 4.1 slipon and NOTHING like my other bikes.
I have a 2006 yz250f with a flywheel weight which is a beast. I have a 2013 yz250f which is also a beast. Both are stock minus an exhaust on the 2006 but the 2013 is completely stock.
Any ideas where to look. It does ok on level ground but under a load like a hill it shows its lack of power. Air filter is clean, oil is new. I am at an absolute loss. IF I could get electric start and power similiar to my 06 yzf this might be the best bike ever made by man so please help.
Old 10-20-2013, 10:34 PM
Ignition timing/CDI? Head?
Old 10-20-2013, 10:43 PM
What would I check on the CDI or head?
Old 10-21-2013, 01:58 AM
Head - Valve clearances/sealing
CDI - No idea how you'd check it short of swapping it for another. Is it the same as the ones on the Yamahas? Maybe..
Have you done a leak down test on it at any point?
Is it possible that the engines making power but not getting it to the wheels? ie slipping clutch/heavy rear tyre & chain/flywheel mass?
Whats the tune like? Are you running the same needle/jet combo across all 3 bikes?
Old 10-21-2013, 07:22 AM
Had the valves shimmed up with the new piston. Haven't done a leak down check though. I don't have any clue on the jetting mostly because there is a quick shot on there and don't know much about them.
I would assume it is a wr cdi but I don't know that. Will have to check before I try. It would be nice to put a yz250f one in but I am sure I am not that lucky.
Good stuff. I have to unload today from my 4 day Missouri trip and hopefully start later today.
Old 10-21-2013, 03:21 PM
Any chance you can swap the carbs over?
Old 10-21-2013, 04:13 PM
That is a great idea.
I will just take the throttle and everything and shouldn't be THAT hard.
Old 10-21-2013, 04:35 PM
jhendr3702's Avatar
that is a great idea... wonder if the gg wr needs the throttle stop thing done ? swapping carbs would tell you for sure..
http://thumperfaq.com/throttle.htm
Old 10-21-2013, 04:54 PM
Hawkeye Hawkeye is offline
He states it doesn't have any restrictions on it. It would be easy to tell if there is a throttle limiter on the GG's engine just by looking at the throttle cable at the carb, or peering into the back of the carb to watch the slide open.
My thought is to check the airbox on the GG. Is it restricting airflow some way when compared to the the YZ box? I would have said the silencer but you changed that. My experience with WR250's is that the stock silencer cuts down on top end power. That got me thinking what else is cutting off airflow. I'd try running it without it's seat and/or comparing the jet size between your '06 Yamaha and the GG.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 10-21-2013, 07:54 PM
It certainly looks like I need to drop the subframe to get it out. The shock at very least. Am I seeing this correctly?
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
EC 300 Rattling & power loss ??? Porkyblader Enduro Engine - 2 stroke 7 09-09-2011 09:11 AM
Your 300 Power loss solution? socalscott Enduro Engine - 2 stroke 3 07-14-2011 08:39 PM
Old gas and power loss? EcEvan03 General Discussions & Announcements 16 04-27-2011 06:40 PM
power loss glassman581 Enduro Intake/Carburetion - 2 stroke 3 03-22-2011 11:19 AM
