ICS springs.
Where do you buy these for the 48 Zokes? I'm thinking of replacing the 1.6 with a 1.4 to try to get a bit better low speed plush.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300 |
Rumor has it that we have some
You haven't already shipped them?
I'll give you a call. I have a set of 48mm Zokes off a 2014 350 Beta Race I picked up and I've been told a few of them have issues with the bushings causing very high wear on the fork tubes because they do not align properly when the forks flex. Apparently they fixed the issue by machining the inner tube in such a way the bushings slightly rock. I'd hate to trash a brand new set of forks.
One of our local suspension guys told me the ICS spring on the '15's is a 1.4 versus the 1.6 on the '14's making for a bit more plush ride in the really rocky root infested areas. I almost exclusively ride really tough trails since my go fast desire has kind of gone away as I get older (a lot older). I assume you can easily fix any factory issues. The '14 Beta Sachs worked fairly well. The Zokes are a bit more harsh everywhere although they certainly don't bottom out as easily.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300 Last edited by Ud_luz; 03-29-2015 at 10:53 AM. |
springs | Gasgasogeros | Enduro Suspension | 9 | 01-04-2010 06:14 AM |
What springs should I use? | 2 strokes 4 life | Enduro Suspension | 11 | 03-21-2009 09:22 PM |
