how to stop spooge with Q stealth
As many of you may know the FMF Q stealth drips black oil out the end no matter how spot on the jetting is, the silencer is just too large a diameter and never gets hot enough to let the oil properly burn off.
The solution is found with Honda part # 18357-GBF-830 ,the exhaust gasket from a 96 through 04 CR80/85. I believe 2 come in a package. Use HI-TEMP RTV red or black to "glue" the gasket into the very end of the Q stealth, you may also want to stretch the gasket larger so that it sits more snug. wait for RTV to dry. You will notice much less oil to almost none, a lot less messy. The rearson why this works is the ring "catches" the oil and stops it from draining out the end and drains back into the packing were it has more time to burn off if you ever take a close look at a FMF shorty pipe you will notice this ring put in place as well BTW I am new to the forum, I recently picked up a 2006 EC200 with 2011 conversion |
Tricky stuff
I think I would rather have it all come out than soak my packing.
I started using a lower flash point oil, Klotz Motorcycle Techniplate TC-W3. Not the Super Tech or the R50. If you are not on the pipe enough for your jetting, you will have spooge. With this TC-W3, it is designed for us normal type would ride off the bottom/luggers. The smoke is drastically reduced and after 50 miles, I had a 2" little dribble out the end of the Q. I called Klotz and they strongly advised to use the TC-W3 vs the more popular two. Plus is smells like dirt bike sex... image.jpg
Blanco Current ride: 2009 WR450 Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F |
Like.
Thanks
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public |
How do you stop the brake pedal bolt from bending on the 2010/11 frames? | flo | Enduro Chassis & Body | 7 | 11-10-2013 07:16 PM |
Spooge? | Krieg | General Discussions & Announcements | 17 | 07-05-2011 11:28 PM |
Spooge | Lildawg | Enduro Engine - 2 stroke | 5 | 04-19-2011 08:47 PM |
Has Anyone got a nice solution to stop the top of the Ohlins shock wearing | stay_upright | Enduro Chassis & Body | 11 | 08-20-2008 12:17 PM |
