Old 05-06-2016, 07:52 AM
phoenix's Avatar
phoenix phoenix is offline
I checked the parts fiche for a 2014 and it says:
HS1 12V35-35W
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 05-06-2016, 11:52 AM
Anders's Avatar
Anders Anders is offline
HS1 12V35-35W
Yes the OEM bulb is not a H4, it just looks like one. But I guess a H4 would fit. However, H4 lamps are 60w or even more in some case and the GG generator wouldn't be able to drive it properly I think. I used a H4 bulb in my 06, but had to turn the light off when I used the heated grips.
But a LED in a H4 casing would be a good alternative. I haven't tried anything like that, as I use a bright helmet light during winter.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 05-07-2016, 08:05 AM
Zman's Avatar
Zman Zman is offline
I am very sorry for the confusion! The older GG bikes used the bulb with the other base.
Old 08-22-2016, 07:18 PM
GGRider01 GGRider01 is offline
Aren't the more recent bikes using H4?
http://www.ebay.com/itm/2x-H4-120-LE...9XAeyk&vxp=mtr
Anyone tried these? Hi/Lo or just one setting?
Small bulb in headlight assembly? liv2day Enduro Chassis & Body 10 06-11-2014 05:27 PM
2011 headlight bulb skid jackson Enduro Electrical & Wiring 34 11-08-2013 06:51 AM
LED H4 bulb desertgasser300 Enduro Electrical & Wiring 10 10-04-2013 09:39 AM
Spring to hold in headlight bulb c337b Enduro Electrical & Wiring 1 10-09-2011 02:04 PM
Headlight Bulb Kurdt Enduro Electrical & Wiring 1 09-01-2010 10:23 PM
