Old 05-14-2019, 08:02 PM
andrewjtheis andrewjtheis is offline
Default Help crank shaft play
Hey guys. Need a little help. I?ve been a diesel mechanic for nearly 20 years, but 2t is a little foreign to me. Even on a 8cyl Detroit this much play is NUTS! Please take a look at the vid (it?s 11sec long) and let me know how fcked I am. Thanks all. https://youtu.be/P3uLmZxEmk4
Old 05-14-2019, 09:02 PM
arminhammer arminhammer is offline
She is a no good!!!
Old 05-14-2019, 09:16 PM
Yep that left hand side main bearing is cactus bud. If it is a early model Gasser you can replace the crappy roller bearing for a ball bearing. I?ve found they last way longer than the rollers do. It may have had those silly sealed bearing that Gasgas persisted with for a few years too, Had the motor been drowned before? What year is it?
Old 05-14-2019, 09:33 PM
It?s a 2010 EC250. I thought it was running rough due to jetting. Well... not likely. I?m absolutely crushed because I sold my KTM to make room for this bike (just got it, never ridden it except testing).
Old 05-14-2019, 11:45 PM
Rebuild it and it will be a better bike than the Ktm mate. It does suck when you buy something that has been poorly maintained. 2010 had the silly sealed main bearings. If you buy aftermarket ones make sure to pluck the seals out.
Old 05-15-2019, 01:13 AM
Does she vibe a lot?
The bearings are C4 so some play is expected (on a cold engine particularly), but from your video sounds excessive.
My 2010 had the sealed mains mentioned above. They lasted 260hrs and were ok when pulled down but there wasn't a lot of lubrication left in them.
These engines are easy to work on. Given that she's a new bike to you think of it as foreplay! Crack her open and see how the slug and big end looks. A couple fresh mains and button her back up. You'll know where you're starting from and get many hours enjoyment from it.
Regards poor running, have a look in the carb..
Old 05-15-2019, 04:31 AM
I had loose engine mounts. My newly rebuilt mains looked pretty sloppy when diagnosing it. No problem.
Old 05-15-2019, 04:42 AM
Yerp.. After rebuilding my 2010 I recall taking a video and having concerns with some similar play. Wasn't same as the video from what I recall but with the reed valves out I certainly could hear some movement when lifting the flywheel.
Found the video I had uploaded to youtube.. This is a freshly rebuild engine (every bearing replaced). https://www.youtube.com/watch?v=87yovgws65I
Old 05-15-2019, 06:46 AM
Do you have to split the cases to replace this bearing? I?ve never done it and don?t have the engine manual. The guy I got it from offered to fix or buy back from me. Considering both but I think I?ll let him buy it back.
Old 05-15-2019, 01:08 PM
Yes you have to split the cases, full motor strip.
GG FSE 450 crank shaft and other parts [rebuild] V1T0 Enduro Engine 4 stroke (including EFI & Exhaust) 8 10-27-2018 11:43 PM
Shift shaft play Stamper Enduro Engine - 2 stroke 4 01-31-2016 05:20 PM
How much crank play in a 99 is OK? funmachines Enduro Engine - 2 stroke 8 10-03-2013 03:48 PM
Crank end play CDBiker220 Enduro Engine - 2 stroke 12 02-13-2011 05:22 PM
Waterpump shaft end play SpeedyManiac Enduro Engine - 2 stroke 1 04-08-2009 09:05 AM
