Running hot
My bike steams some coolant after longer climbs. I'd say that I'm at mid throttle during most of the climb. I'm moving at a decent speed so there's air moving through the (clean) radiators. It's fine when back on level terrain.
After a normal 30 mile ride, with some hills, the coolant level is an inch or two below the fins. My 1st thought was that the cap (1.5) may have gone bad. I switched to the stock (1.2) and it was no worse and no better. I looked at the (LTR) impeller and it looks fine and turns when I kick the starter. My next thought was that I was lean (2nd clip slot, 178 main). My buddies said my exhaust is smokey and think I may be rich. My needle seat could be wearing/worn, too ? I should have taken a plug reading after the hill but I figured it'd be better to just ride easy and keep some air moving over the radiators and coolant flowing. It's an '03 EC300 with a fresh top end. The issue existed before the new top end. Oil has looked good at changes. Last edited by Brian VT; 09-30-2008 at 07:01 AM. |
Anyone Running Engine Ice? | lordfeyr | Enduro Other... | 14 | 06-25-2011 10:16 PM |
Running rich | Evans P | Enduro Intake/Carburetion - 2 stroke | 2 | 02-26-2010 12:50 PM |
02 400 fse running prob | dan j | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 08-14-2008 05:44 AM |
Running rich | rustygun | Enduro Engine - 2 stroke | 4 | 06-20-2008 04:18 PM |
Running In | Dingo | Enduro Engine - 2 stroke | 3 | 07-26-2007 11:36 PM |
