Old 09-01-2018, 05:12 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Default PWK38 Service kit ?10
So I purchased a Keihin PWK38 refurb/service kit for 10 Euros including p&p!
I have a 2004 EC300 with PWK38 AS1 Screw Top Carb. Had it a few years, got it jetted just nice (using genuine Keihin jets and needle) but I still had a few niggles with the carb... intermittently overflowed fuel, idle was unstable, etc.
I don't use the bike for competition, leisure use only but I ride it hard.
I spotted the PWK38 refurb/service kit on eBay from China for only 10 Euros with postage, for the money I thought I'd give it a try!
Obviously, it's not genuine Keihin, some people may call it 'fake' others may call it 'pattern' but it contained some parts that would be very useful...if they worked!
So after 2 weeks it arrived and I have to say I was pleasantly surprised.
As well as other parts, the kit included a Main Jet, Pilot Jet, Needle and Slide. I decided I wouldn't be using these and put them to one side.
Here's a list of the parts I used from the kit...
1. Float - Original float had been bent/adjusted many times, its tang was deformed and I didn't trust it.
2. Float valve - Original float valve looked in good condition but the rubber tip had hardened and the spring action of the spring loaded pin seemed very light.
3. Choke plunger - The rubber tip had hardened and was indented.
4. Float Bowl seal and Jet Block seal - both rubber seals had hardened and flattened.
5. Air Screw - It had a ridge on its tapered tip.
6. Plastic Idle Screw - Screw head was damaged and tip worn.
I stripped and cleaned the carb, fitted the replacement parts. The float/float valve needed no adjustment. Straight out of the box they gave me a float height of 16mm with the float seam parallel to the bowl mating surface.
I've had a 3 hour ride on the bike this afternoon and all is good. The intermittent carb overflow is fixed and I can adjust the air screw/idle screw to give a stable idle.
If I was using the bike for serious competition then I'd happily spend money on genuine Keihin parts, but for what I need I'm very happy with my 10 Euros kit!
Old 09-01-2018, 07:17 PM
Harry's Avatar
Harry Harry is offline
Hi Dave, do you have a link ?
Old 09-02-2018, 02:46 AM
Davehuge's Avatar
Hi Harry
Here's a link to the kit I purchased from China...
Motorcycle Repair Kit 38mm For PWK KEIHIN OKO Carburetor Spare Sets One Pack https://ebay.us/kgSSkW
This fits the Keihin PWK 38 AS1 carb with screw top.
My kit came with a 170 Main Jet, 55 Pilot Jet and a DDJ needle, but to be honest I have thrown these in the bin and I will only use genuine Keihin Jets/Needles.
All the best, Dave.
Old 09-02-2018, 10:20 AM
Does the slide match your stock slide? I assume it is a generic kit so it will have different jet sizes and potentially a different slide cutout.
Old 09-02-2018, 12:38 PM
Davehuge's Avatar
Hi Zman, to be honest the slide had no identifying mark/number on it, I didn't use it and it will probably end up in the bin along with the jets and needle.
Cheers, Dave.
Old 09-02-2018, 08:43 PM
Harry's Avatar
Thanks Dave
Old 09-03-2018, 01:28 AM
What would be nice is if they did a tower with the needle jet orifice as that can potentially ovalise with the needle vibrating. Have seen that as a spare on some atv website for similar carb.
Happy as with my late model carb conversion though but $10 kit looks great deal if you are careful with what to use.
When you have the tower out use a magnifying viewer and really have a good gawk at the needle orifice to check it is round.
TTX 44 Service Manual Jacob 'Berg Enduro Suspension 3 04-15-2016 08:08 PM
09 EC 300 service manual kevinlowney General Discussions & Announcements 1 06-27-2012 01:27 AM
service manual skid jackson Enduro Engine - 2 stroke 5 05-04-2008 08:11 PM
2003 pro 200 service dvd Craig1413 Other GasGas Bikes/Quads 1 11-24-2006 05:29 AM
