#11
Yes, that was me. My '03 had some burrs on the alloy backing of the friction discs that would apparently hang up on the basket. Once cleaned up with a file the clutch was flawless.
If it drags as bad as you say there is a problem. Once warm I can find neutral pretty easy and in gear starts are no problem, even with 15-40 Rotella. Could your master cyl be leaking slightly? Sent from my iPad using Tapatalk HD |
#12
ATF type F works a treat for me
Thread Tools | |
Display Modes | |
gear box oil | weaver | General Discussions & Announcements | 20 | 02-15-2012 11:38 PM |
how much gear oil | boostedte37 | Enduro Engine - 2 stroke | 4 | 04-08-2010 03:13 PM |
Gear oil? | nick790 | Enduro Engine - 2 stroke | 7 | 05-18-2009 06:54 AM |
skipping gear. | rupecopp | Enduro Engine - 2 stroke | 22 | 03-04-2008 06:45 AM |
Gear problems... | jonnyweston | Enduro Engine - 2 stroke | 3 | 01-04-2008 05:55 AM |
