Old 10-11-2010, 05:09 PM
eff's Avatar
eff eff is offline
I just quit using the Rotella this season. I'm running Amsoil 0W-40 now and love it. I always had a hard time finding neutral with the Rotella, but no issue now with the Amsoil.
2004 GasGas DE250
Old 10-11-2010, 11:01 PM
For those who cannot get rotella oil most agricultural diesel engine oils work pretty much the same. Just think you need to change it more often
I have used the recommended GRO 10-30 gearbox oil and belray gear saver oil and both work well
Old 10-12-2010, 12:28 AM
noobi's Avatar
noobi noobi is offline
What are you guys paying for a gearbox full of oil? So for a litre I guess, I over full so I dont have 100ml of oil sitting around idle.
FYI, I pay 13NZD (10USD) for a 1L of Elf Moto Gearoil 10W-40
Or I can use Elf 4HP eco, 8NZD per L, which is a semi synthetic engine oil that all of the guys who I work with, MR Motorcycles, use in their 2 strokes, and 4 strokes.
Old 10-12-2010, 01:26 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
I use GRO gear oil and use 900ml. The 1000ml bottle costs about $25 bucks from memory.
Cheers Mark
Old 10-12-2010, 01:54 AM
iancp5's Avatar
iancp5 iancp5 is offline
On that recommendation I'd use Rotella if I could get it here. I have no problem finding neutral and would like to find it less often!
In case other UK riders would like to find neutral as often as I do, I use Putoline Light Gear Oil. Clutch action is good.
Old 10-26-2010, 06:13 AM
motorhead's Avatar
motorhead motorhead is offline
Got a good laugh out of that one,funny thing I hit more false nuetrals than I have in a long time at sundays slimefest/I mean district enduro after ratio riting 900cc of fresh t6 retella in sat.nite??( I think it was the muddy conditions!) Paid $19 for gallon so whats that?-$4.75 an oil change for slick shifting/no clutch squeal/chirping and best part I dont change it as often. I run it about 8-10 hours before draining
Old 10-26-2010, 06:44 AM
einsteingarage einsteingarage is offline
I usually use Rotella but I have 2 qts of Hypoid Gear oil 80w90 kicking around.
Does anyone know if I could use this in the gearbox? I would think so but maybe some oil experts on here have an opinion.
Old 10-26-2010, 07:36 AM
Zeal Zeal is offline
Synthetic gear oil designed for a 2T trasmission is the best choice.
Under heavy use oil with no friction modifiers will wear out the clutch. Rotella will break down quickly. In my experience it will smell burn after one ride.
Just a suggestion.
Old 10-26-2010, 07:44 AM
we paying the equivalent of US$13 for a litre of gro racing oil or belray gear saver
Old 10-26-2010, 11:50 AM
bchatt's Avatar
bchatt bchatt is offline
I would definately not use hypoid 80/90 gear oil. It is designed for heavy diffs and gearboxes (cars, trucks). It is much too thick for bike gearboxes - your clutch will drag hugely with that stuff.
Barry
07 EC250
Noisy transmission 07 fsr 450 fastisbetter Enduro Engine 4 stroke (including EFI & Exhaust) 6 04-08-2010 07:20 PM
transmission oil on ec250 twibs Enduro Engine - 2 stroke 1 03-15-2008 09:13 AM
No oil in Transmission RPB111 Enduro Engine - 2 stroke 5 03-17-2007 08:49 AM
EC250 '00 transmission in MC250 '05 Leon_gasgas Enduro Engine - 2 stroke 12 01-10-2007 03:10 AM
