Old 06-29-2017, 05:55 PM
Longo117 Longo117 is offline
Default Clutch issue
Ok bear with me guys n gals. This is my first bike with a hydra clutch .its a 2017 ec300. It doesnt even have an hour on it yet .I cant figure out why in the world the clutch pulls like it does when i try starting it in gear . Ive adjusted all the settings on the lever making it closer all the way out, nothing . Im just confused. How to i set where the grab is on the lever . Im used to the old ways of cables and a twister adjustment! . Any help would be greatly appreciated .
Old 06-29-2017, 08:18 PM
Heya.
Well it could be the basket is a little sharp and grabbing the plates and little. Maybe some hours might help. Or it could be the clutch needs a bleed (fluid type written on Mc top. Often mineral oil rather than brake fluid)
Also read oil threads. I find Motul Transoil Expert works great but Transoil standard drags.
Good luck and stick around to read the jetting threads. You won't believe how much better a different needle will make the bike run.
Old 06-29-2017, 08:32 PM
pscook's Avatar
pscook pscook is offline
What exactly is the issue? Is the bike hard to start in gear? That's normal for a wet plate clutch. Is the clutch engaging/disengaging too early or late? That should be an adjustment at the lever, or it could be too new of a clutch and needs to wear in. Is the bike hard to push around when in gear and not running? Again, it could be that the plates are too new.
Automotive motor oil will cause the clutch to drag as well as the fact that your bike is still wearing in (as F5 mentions). Try another oil, such as ATF or a blend of ATF and motor oil. I prefer a 75/25 blend of 10w30/ATF. Even a 90wt gear oil (or 80) might work for you. I would suggest riding the bike for a few hours and see how it does.
Not be dismissive, not at all, but a new bike might need some time to fully settle in. For example, the suspension requires about 10-12 hours to really "break in," so go and ride it and see if the clutch changes.
Phil
(New bike pending...)
Old 06-30-2017, 01:22 AM
You'd be amazed how many people don't realise how much drag there is on a clutch until they go to push their bike in gear with the engine off, clutch pulled and think OMG something is wrong.
On a cold engine it is most noticeable as the plates have had time to stick together. I usually rock the bike a few times before I start her to reduce intial drag. With the oil I run it's never an issue when at temp.
Old 06-30-2017, 07:04 AM
Thanks for everyone replies i truely appreciate it .it just seems to want to lurch forwards when i start it this was even after being warmed up for about 10 min and riddenndrom my house to my garage
I was just playing with it to make adjust ment for harescramble starts and it just seemed wonky to me . Ill try everything u guys said thanks you very much !
Old 06-30-2017, 11:25 AM
hamilton's Avatar
hamilton hamilton is offline
Like others have said, put some break in time on it.
Some of us have had problems with the AJP clutch master cylinder not holding pressure on 14/15's. Mine lasted for a day, some ride time will tell.
15 GASGAS EC 250
19 Sherco SE 125R
Old 08-15-2017, 04:41 AM
periclesgsilva periclesgsilva is offline
U mean Lever failing when u need to use a clutch big time? No clutch on Lever?
Enviado de meu SM-G935F usando Tapatalk
Old 08-15-2017, 06:28 AM
hamilton's Avatar
Yes, the master cylinder seals were ruined from piston debris not being cleaned after machining.
15 GASGAS EC 250
19 Sherco SE 125R
Old 08-21-2017, 09:10 PM
compmoto's Avatar
compmoto compmoto is offline
Default clarification please
are you meaning from new ? as in from the factory ? I've had a 125 that I've rode approx. 45 mins with no issues, then another 15-20 mins and piece of what appeared to be "welding slag" was found in the slave piston area, seal was toast, and it beat on that end of the slave cylinder...enough to warrant replacement... I am trying to understand how anything could be in there from the factory ! I've never heard of it before on a new bike anywhere...
XC300,RM250,X440,EC125
https://www.facebook.com/groups/gasgasoffroadriders/
Old 08-22-2017, 11:20 AM
hamilton's Avatar
Originally Posted by compmoto View Post
are you meaning from new ? as in from the factory ? I've had a 125 that I've rode approx. 45 mins with no issues, then another 15-20 mins and piece of what appeared to be "welding slag" was found in the slave piston area, seal was toast, and it beat on that end of the master cylinder...enough to warrant replacement... I am trying to understand how anything could be in there from the factory ! I've never heard of it before on a new bike anywhere...
Yes, from factory, straight off showroom floor. It was just poor quality control from AJP. I know of 4 that had the same problem and 2 that didn't in my area (14/15's). Replacement with a Magura master cylinder is the easy cure, has a much better feel also.
You say your slave piston seal(on engine) was damaged? I don't follow how that had any effect on the master cylinder???
15 GASGAS EC 250
19 Sherco SE 125R
Clutch master issue Bulgas Enduro Engine - 2 stroke 13 01-29-2014 10:53 AM
clutch issue gasn4christ Enduro Engine - 2 stroke 4 10-13-2013 03:02 PM
2003 ec250 clutch issue dirt2road Enduro Engine - 2 stroke 12 08-17-2012 03:15 PM
Clutch Drag Is Not An Issue! Rick Pictures & Videos 7 11-25-2010 07:50 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
