Old 06-29-2017, 05:55 PM
Longo117 Longo117 is offline
Default Clutch issue
Ok bear with me guys n gals. This is my first bike with a hydra clutch .its a 2017 ec300. It doesnt even have an hour on it yet .I cant figure out why in the world the clutch pulls like it does when i try starting it in gear . Ive adjusted all the settings on the lever making it closer all the way out, nothing . Im just confused. How to i set where the grab is on the lever . Im used to the old ways of cables and a twister adjustment! . Any help would be greatly appreciated .
Old 06-29-2017, 08:18 PM
(F5) (F5) is online now
Heya.
Well it could be the basket is a little sharp and grabbing the plates and little. Maybe some hours might help. Or it could be the clutch needs a bleed (fluid type written on Mc top. Often mineral oil rather than brake fluid)
Also read oil threads. I find Motul Transoil Expert works great but Transoil standard drags.
Good luck and stick around to read the jetting threads. You won't believe how much better a different needle will make the bike run.
Old 06-29-2017, 08:32 PM
pscook's Avatar
pscook pscook is offline
What exactly is the issue? Is the bike hard to start in gear? That's normal for a wet plate clutch. Is the clutch engaging/disengaging too early or late? That should be an adjustment at the lever, or it could be too new of a clutch and needs to wear in. Is the bike hard to push around when in gear and not running? Again, it could be that the plates are too new.
Automotive motor oil will cause the clutch to drag as well as the fact that your bike is still wearing in (as F5 mentions). Try another oil, such as ATF or a blend of ATF and motor oil. I prefer a 75/25 blend of 10w30/ATF. Even a 90wt gear oil (or 80) might work for you. I would suggest riding the bike for a few hours and see how it does.
Not be dismissive, not at all, but a new bike might need some time to fully settle in. For example, the suspension requires about 10-12 hours to really "break in," so go and ride it and see if the clutch changes.
Phil
(New bike pending...)
Old 06-30-2017, 01:22 AM
You'd be amazed how many people don't realise how much drag there is on a clutch until they go to push their bike in gear with the engine off, clutch pulled and think OMG something is wrong.
On a cold engine it is most noticeable as the plates have had time to stick together. I usually rock the bike a few times before I start her to reduce intial drag. With the oil I run it's never an issue when at temp.
Old 06-30-2017, 07:04 AM
Thanks for everyone replies i truely appreciate it .it just seems to want to lurch forwards when i start it this was even after being warmed up for about 10 min and riddenndrom my house to my garage
I was just playing with it to make adjust ment for harescramble starts and it just seemed wonky to me . Ill try everything u guys said thanks you very much !
Old 06-30-2017, 11:25 AM
hamilton's Avatar
hamilton hamilton is offline
Like others have said, put some break in time on it.
Some of us have had problems with the AJP clutch master cylinder not holding pressure on 14/15's. Mine lasted for a day, some ride time will tell.
15 GASGAS EC 250
19 Sherco SE 125R
Old 06-30-2017, 12:18 PM
arminhammer arminhammer is offline
I took a die grinder and cleaned up between every pad on the fiber discs on my wifes 11 250. The clutch is now better than anything I have ever used. It takes some time but did wonders.
Old 06-30-2017, 01:31 PM
Neil E. Neil E. is offline
Cleaning out between the pads so the grooves go down to the base material?
Old 06-30-2017, 06:06 PM
You got it Neil.
Old 08-15-2017, 04:41 AM
periclesgsilva periclesgsilva is offline
U mean Lever failing when u need to use a clutch big time? No clutch on Lever?
Enviado de meu SM-G935F usando Tapatalk
Clutch master issue Bulgas Enduro Engine - 2 stroke 13 01-29-2014 10:53 AM
clutch issue gasn4christ Enduro Engine - 2 stroke 4 10-13-2013 03:02 PM
2003 ec250 clutch issue dirt2road Enduro Engine - 2 stroke 12 08-17-2012 03:15 PM
Clutch Drag Is Not An Issue! Rick Pictures & Videos 7 11-25-2010 07:50 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
