Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 11-14-2014, 05:57 PM
gasser's Avatar
gasser gasser is offline
Default DID "U" wheel set
Professionally powder coated to any color you pick. Hub and spokes will be the same color. Rims are straight, no dings, spokes are tight. Taking offers
Old 12-12-2014, 10:45 PM
cbutler's Avatar
cbutler cbutler is offline
Bump for my buddy Ken since hes taken over.
Cant you lump it all in one post and edit it as parts are sold 4 frigin pages COME ON MAN
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 12-13-2014, 07:05 AM
mcnut's Avatar
mcnut mcnut is offline
To quote a prominent politician, "what difference...does it make?"
Old 12-16-2014, 02:58 AM
wrench's Avatar
wrench wrench is offline
BUMP it makes a lot of difference.
The kind of difference, that's why people keep mentioning it!
2003 GG 300EC/DE [Ohlins]
2001 GG 250XCSOLD
Old 12-16-2014, 11:21 AM
Banned
Do you have any pics? And what year does the front fit?
Old 12-16-2014, 12:28 PM
gasser's Avatar
Wheels are from a 2001 GG300. They are currently silver but I can have them powdercoated any color you like however I will not dismantle the wheels so spokes, wheel, and hub will all be the same color. Front wheel would require larger bearings to fit any gasser 2007 or later because of the larger axle. Rear would require a different spacer and outer bearing on the drive side to update it to newer models.
Old 12-18-2014, 04:17 PM
wrench's Avatar
PM sent your way
2001 GG 250XCSOLD
Old 12-18-2014, 11:31 PM
smallpuffydog's Avatar
smallpuffydog smallpuffydog is offline
Bronze Level Site Supporter
I'm not familiar enough with the powder coating process, but it sounds like there isn't a way to coat just the rim without taking the wheel apart...is that right?
Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. [Buddha]
Old 12-19-2014, 01:01 AM
gasser's Avatar
Correct, an electrical charge holds the powder to the part after being sprayed on. The part is then baked at something like 350-400 degrees which changes the powder to a more paint like substance.
Old 12-19-2014, 07:29 AM
shang shang is offline
They do have a masking tape designed for powdercoat, but I'm guessing it would be just as time consuming to mask all of the spokes as it would be to just disassemble the wheel. And if you disassemble the wheel, you might as well have the hoop anodized.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Wheel set with DID Dirt Star "U" rims Skidad Parts 9 11-13-2013 09:45 PM
'06 EC300 Rear wheel "top-hat" bushing Eugene Enduro Chassis & Body 1 01-23-2009 10:27 AM
"attn." "new England Boys" RONALD BRUNDIGE General Discussions & Announcements 9 11-17-2008 08:19 PM
Recommendation: add "Injury/Recover" and "Riding Techniques" sections MattR Suggestion Box 2 07-18-2006 09:19 PM
