#21
So from your sketch you just swapped your white and yellow wire coming out of the stator?? And now you have the yellow wire going to the stock AC and the yellow wire going to your ac/dc RR??
#22
Yep swappped, yellow from stator to r/r, and white to original ac reg
Skickat från min iPhone med Tapatalk |
#23
That's an odd way of doing things, but if it works why not? You should be able to disconnect the white wire and get the same result.
Your problems made me think that the white wire was not making good contact and that caused your voltage drop. The other way this could occur is if somehow you had a connection that was grounding both sides of the rectifier.
2011 EC250E |
#24
Yea, ive been thinking as well, i think i had a bad connection with my white wire.. but hell its working now anyhow
Converting a 250 to a 300 | Niall-griffiths | Enduro Engine - 2 stroke | 14 | 11-16-2014 05:23 PM |
Converting a EC200 to a EC300 | Ply318ci | Enduro Engine - 2 stroke | 19 | 12-12-2011 08:28 AM |
Converting a Sachs shock to fit a bladder? | Keg | Enduro Suspension | 12 | 06-22-2009 11:17 AM |
Converting 2009 EC300 to Motard | cheekeon | Enduro Chassis & Body | 0 | 04-12-2009 03:04 AM |
