Old 12-19-2016, 09:20 PM
chopper chopper is offline
Originally Posted by Zman View Post
Does the KTM 2k3 stator work in the GG?
Yes I used one on my 03, KTM # 50339004200, plug and play including the plate!
Old 12-20-2016, 07:33 AM
Getoviq95 Getoviq95 is offline
Yes guys the winding is damaged ,i know that ,because the bike haven't spark .Today I solved the first problem -welded the broken piece .Tomorrow I'll send the stator for new windings .The ktm stator 2k3 kokusan is crossover part with gas gas ,but i just wanna save some money .And i have one questions ,my stator have resistance like in a manual :impulse coil is 100ohms ,exciter-13,1ohms .Is this possible ,if the winding is damaged ?
Old 12-20-2016, 10:12 AM
Anders's Avatar
Anders Anders is offline
If the resistance of the windings are as described in the manual, I would say its OK
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 12-20-2016, 11:32 AM
The damaged winding is for headlight ,i'll try to start a bike .
Old 12-22-2016, 04:38 AM
I putted a stator and rotor back ,but i haven't spark again .Impulse coil show 100ohms ,exciter 13,1 and ignition coil-13,36k ohms everything looking OK ,Is the cdi dead ?What do you think ?
Old 02-14-2017, 10:57 AM
Now the stator is with new winding ,but still no spark .I'm sure ,that the problem is in pick up coil ,because the bike have spark with my friend's stator . Do you know how is the distance between pick up coil and winding ?Or between pick up coil and the rotor marker.I'll be very thankful !
http://prikachi.com/images.php?images/525/9041525q.jpg
Old 02-20-2017, 11:06 AM
I solved the problem ,and now have a spark .The air gap between pulse/pick up coil and rotor's marker is under 1mm .
Stator Plate GGRider01 "Wanted to Buy" & "Want To Trade" 0 06-24-2016 01:40 PM
WTB Stator Plate for K3 (Large Ignition) Jim Cook "Wanted to Buy" & "Want To Trade" 2 05-20-2014 09:31 AM
Broken Clavical GMP Injury & Recovery 68 06-17-2009 07:09 AM
broken clutch?? Simon_R Enduro Engine - 2 stroke 2 07-23-2007 05:50 AM
Broken Link Dingo Enduro Engine - 2 stroke 3 07-07-2007 07:15 PM
