#11
Yeah. So like a battery. The output of the reg is 12ish volts +. Cap+ here. The - of cap to earth . your light is earthed I assume.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#12
The output is grounded
#13
In a different topic you stated that you are using the Ducati stator that has two yellow wires and a red wire. Your grounded rectifier output is OK as long as your stator red is NOT grounded.
2011 EC250E |
#14
I used just 1 of the yellow wires and the red straight into the R/R is that wrong?
#15
No, that's perfect. I'm just confirming that only one side of the reg/rect has been grounded. So basically the plus from the reg/rect output goes to various switches and then to your loads. The other side of the loads are connected to minus (which is grounded).
I have no explanation for lights turning off at high RPM if you have a battery (or capacitor) in the circuit. Without a battery (or cap) the reg/rect may do strange things. Maybe the r/r you have is faulty.
2011 EC250E |
#16
This happen with halogen lamp too?
Led ohms can be too small.
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
#17
Standard setup for a Honda CR or RS with digital ign is regulator and Cap.
#18
Well thanks for all the replies fellas, i'll get a capacitor bought and wired in.
#19
Get down to the shop and knock on the doors till the slackers open up.
Thread Tools | |
Display Modes | |
FOR SALE, 250XC forks, NEW fender, front wheel, front wheel bearings | iamyvr | Parts | 5 | 07-27-2014 08:18 AM |
2011 Front Fender with 2010 Headlight | Jakobi | Enduro Chassis & Body | 4 | 05-24-2013 11:55 AM |
lights flickering and going off when revved | Elliker | Enduro Engine - 2 stroke | 9 | 01-21-2009 05:28 PM |
06 EC300 - strange sound when over revved | colinmc400 | Enduro Intake/Carburetion - 2 stroke | 5 | 05-02-2008 12:10 PM |
