Power valve not working
Hi guys searched the forums and read heaps on these things not working and adjusting slack and preload and such. My problem is that on throttle my valve is hardly moving. I have taken the actuator arm off and the triangle plate has fre movement and the actual valves move freely with this motion. I adjusted the preload slack previously when I did the top end about 20hrs ago. Complete new top end, jug, s3 head, piston/rings, and cleaned valves up also. Went well till I was chasing an electrical gremlin that ended up being the stator, but now I basically have no power band.
Opened up the right cover and as stated tookthe actuator arm off. Triangle plate has very easy full movement from stop to stop. But all hooked up and running t takes almost full throttle for it to move at all and when it does move it only moves sparodically and not very much, like at best 5 mm. Not sure on the governor side if the could be something wrong there. Could there be too much preload?
Bike is an 04 EC300 and b4 electrical gremlin was running wicked
Hopefully get somewhere. This forum is a whealth of info, thx
