Old 11-25-2012, 10:12 PM
70455 70455 is offline
Default 2001 xc250 case sealant with no gasket
Getting ready to put my cases back together but dont have gasket. Is yamabond ok? Ive done this with kx250 i built, but it did not have coolant flowing through both halves.
Sent from my DROID RAZR using Tapatalk 2
Old 11-25-2012, 10:16 PM
gasgasman's Avatar
You will need the gasket.
The gasket is also a "spacer". Not using one will create some clearance issues.
Old 11-26-2012, 08:05 AM
GMP's Avatar
GMP GMP is offline
+1, I test fitted cases dry with no gasket in my '00 years ago and there was thrust clearance problems with the transmission. Use the gasket, but a light coat of Yamabond, Threebond, Hylomar, etc. on it is not a bad idea. I always use a gasket sealer on paper gaskets to avoid problems. If the new replacement center case gaskets are like other gaskets on the '12 (metalized, with a thin rubber like coating) this will not be neccessary.
2001 xc250 crank nut won't budge 70455 Enduro Engine - 2 stroke 10 11-15-2012 11:32 AM
1997 kx airbox onto 2001 xc250 70455 Enduro Chassis & Body 3 10-15-2012 10:23 PM
2000 XC250 CDI for a 2001 UK EC300 krazy Enduro Electrical & Wiring 1 09-14-2008 04:58 PM
