#11
I replaced the lower pipe mount with some yz parts. This has seemed to make the biggest difference. I also switched the exhaust spigot out for a LTR unit as mine was quit worn. I will see. If I can find the part numbers when get home next week.
2018 EC 300 |
#12
Thanks Everyone!! Ill be racing this weekend and after Ill look at everything posted!!
Thank you all greatly for your help! |
#13
Put a sleeve of hose on each spring. If not, the buzzy springs are adding to the other vibration issues you are having.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine |
#14
Yeah, that squeal is loud and annoying. Here is the general fix. Below, is the thread on the vitron rings by Mcmaster. There are two sizes. I use the 44mm id x 3mm wide size some people use the 3.5. I had the same squeal but only after I had jumped over a log or something that hit the bottom of the pipe.
After replacing the rings with new ones the squeal was gone. I'm careful not to jam the headpipe into anything and for the last 8 months no problem. My pipe seems to seal tight against the cylinder so I haven't been beating it with a hammer, at least not yet. http://www.gasgasrider.org/forum/sho...t=vitron+rings
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
High pitch Squealing from exhaust and exhaust flange????? | Scar13 | Enduro Engine - 2 stroke | 5 | 02-11-2012 11:32 AM |
Metal shavings in oil | mikemoto | General Discussions & Announcements | 4 | 08-28-2011 10:51 PM |
Large piece of metal from drain hole??? | desertgasser300 | Enduro Engine - 2 stroke | 16 | 06-22-2011 08:12 PM |
EC250 exhaust O rings? | BIG TOOL | Enduro Engine - 2 stroke | 17 | 09-10-2010 04:31 AM |
Mothers Metal Polish | Boomhauer | Enduro Product Reviews | 3 | 06-23-2007 07:02 AM |
