Tank difference
Hi all.
2002 EC 300 tank part number is BE25001024 2007 EC 309 tank part number is BE25051024 Can anybody explain the difference please ?? Paul |
The 02' tank basically goes up to the neck of the bike, covering the top of the frame. The 07' tank is lower profile and shorter on the top, it shows the frame of the bike between the top mount bolt and the neck of the bike. Also the 02' tank would have a recess in the bottom rear for the upper shock mount. The 07' tank can be used on the older bikes with a little work to the frame.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
What year bike are you working on? The 02?
#1 You need a plate to go between the old mount bolt on the top of the frame to the new tank mount hole. Or you can fab a plate and weld it to the frame for the new mount but not needed to do it that way.
#2 On top of the rear shock area there is a small frame work above the top shock mount, that needs to be removed so the tank can sit down into place since there's no recess in the newer tanks for that bridge.
Fuel tanks available here.
http://www.justgastanks.com/dirt-bik...5-200-250-300/ |
Difference between MC and EC? | Tukt | Enduro Engine - 2 stroke | 5 | 12-11-2016 05:54 PM |
Difference between 13 and 14 300`s | iamovru | General Discussions & Announcements | 4 | 01-06-2015 03:55 AM |
Needles... what's the difference and where to buy? | KTMAndy | Enduro Intake/Carburetion - 2 stroke | 14 | 11-05-2013 12:35 PM |
Whats the difference | joedirt | General Discussions & Announcements | 10 | 01-16-2012 08:21 PM |
2k-2 2k-3 ... difference? | swazi_matt | Enduro Electrical & Wiring | 4 | 10-20-2010 04:52 AM |
