Old 04-11-2018, 06:11 AM
Anglosaxon Anglosaxon is offline
Default Tank difference
Hi all.
2002 EC 300 tank part number is BE25001024
2007 EC 309 tank part number is BE25051024
Can anybody explain the difference please ??
Paul
Old 04-11-2018, 10:34 AM
nknudsen's Avatar
nknudsen nknudsen is offline
The 02' tank basically goes up to the neck of the bike, covering the top of the frame. The 07' tank is lower profile and shorter on the top, it shows the frame of the bike between the top mount bolt and the neck of the bike. Also the 02' tank would have a recess in the bottom rear for the upper shock mount. The 07' tank can be used on the older bikes with a little work to the frame.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 04-11-2018, 03:51 PM
Thanks for your reply. Could you elaborate on 'a little work to the frame' please ??
Old 04-11-2018, 04:31 PM
Fuel tanks available here.
http://www.justgastanks.com/dirt-bik...5-200-250-300/
Old 04-12-2018, 07:47 AM
nknudsen's Avatar
What year bike are you working on? The 02?
Noah
15' TW200
Old 04-12-2018, 04:15 PM
Yes 2002.
Old 04-12-2018, 04:22 PM
nknudsen's Avatar
#1 You need a plate to go between the old mount bolt on the top of the frame to the new tank mount hole. Or you can fab a plate and weld it to the frame for the new mount but not needed to do it that way.
#2 On top of the rear shock area there is a small frame work above the top shock mount, that needs to be removed so the tank can sit down into place since there's no recess in the newer tanks for that bridge.
Noah
15' TW200
Old 04-13-2018, 09:18 AM
Many thanks. This makes sense. May have to go this route if mine keeps leaking
As an aside.... Do these tanks come apart ?? i.e. does the black part at the top separate from the translucent section ?? Looks like a push fit mount or is it welded ??
Old 04-13-2018, 09:52 AM
Have included some pictures. Could you please indentify the offending part that needs removing (If visible ??)
Old 04-15-2018, 08:29 AM
Got it now. It is the recess in the rear underside of the black section of the tank. The later tank does not have the recess so the lug above the shock would need to be removed.
Difference between MC and EC? Tukt Enduro Engine - 2 stroke 5 12-11-2016 05:54 PM
Difference between 13 and 14 300`s iamovru General Discussions & Announcements 4 01-06-2015 03:55 AM
Needles... what's the difference and where to buy? KTMAndy Enduro Intake/Carburetion - 2 stroke 14 11-05-2013 12:35 PM
Whats the difference joedirt General Discussions & Announcements 10 01-16-2012 08:21 PM
2k-2 2k-3 ... difference? swazi_matt Enduro Electrical & Wiring 4 10-20-2010 04:52 AM
