Old 10-05-2018, 07:58 PM
Wypipo Wypipo is offline
Default Super fast idle after removing cable choke
I took the needle, main and pilot out to see what was in there. Put it all back in. Removed the cable choke and put in a plunger choke from a 2018 YZ250. 38mm Keihin PWK just like the GG. Any idea where I should start to see what?s going on?
Before
http://www.youtube.com/watch?v=3JrhP50qUMc
After
Old 10-05-2018, 08:06 PM
One thing I noticed on the cable choke that I removed it has this hole in it. The plunger choke I installed was solid
File Type: jpg 9A506B83-7696-4CB4-A9ED-2D2AED060E41.jpg (86.3 KB, 20 views)
Old 10-05-2018, 08:34 PM
Ok I put the original choke back in and same thing
Old 10-05-2018, 08:46 PM
Make sure the carb is seated in the manifold properly.
If it's not sealing between the carb and reed block it'll suck air and increase your idle. Same goes for other end of carb too, however the front manifold usually needs to be moved a bit to get the 14mm open ender on to change the choke assembly.
Old 10-05-2018, 08:48 PM
The hole is to lock the cable end in.
Check the free play on your throttle cable.
And all the intake hose clamps.
Old 10-05-2018, 08:53 PM
I didn?t loosen the manifold, I just did the two hose clamps on either side and rotated the carb. I did tighten them back
Old 10-06-2018, 07:51 AM
It was my throttle cable. Thanks for the help
Old 10-06-2018, 09:38 AM
Wimpy525 Wimpy525 is offline
Need to watch the throttle cable on these bikes, one snag and its wide open. I always safety wire both ends to prevent it from pull out. I sure that Motion Pro has a replacement cable, just haven't looked yet.
Old 10-06-2018, 10:00 AM
john r b's Avatar
john r b john r b is offline
Motion Pro #10-3000 . This is a good cable, captive at both ends, however i have experienced water seeping into the top of the carb. I could never get a proper seal. Went back to stock.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 10-06-2018, 11:08 AM
RS1 RS1 is offline
What was happening with your throttle cable?
2018 - cable to plunger choke Gibnut Enduro Intake/Carburetion - 2 stroke 0 03-17-2018 12:20 AM
Help! I need a throttle cable for my 1999 EC300....fast! flatout111 Enduro Chassis & Body 5 08-25-2014 01:20 PM
Choke cable eliminator gasgasman Enduro Product Announcements 28 05-09-2011 09:43 PM
choke cable help???? nambo-trev Enduro Intake/Carburetion - 2 stroke 2 08-27-2010 09:23 AM
Cable choke for 03 250? marjastaja Enduro Intake/Carburetion - 2 stroke 3 02-28-2010 09:45 AM
