Old 04-25-2011, 07:57 PM
Lucas Lucas is offline
Default compression? wet or dry?
whats the factory compression for a 2011 ec 300.
been searching here and cant seam to find it.
having bad running issue with the new bike and want to start from square one.
and should i test it wet-oil in the cylinder or dry?
Old 04-25-2011, 08:11 PM
You should have between 160 to 190 psi.
The throttle has to held wide open while kicking the bike over.
The initial test should be done dry.
Oil is added to rule out rings as part of the diagnostic steps.
Old 04-25-2011, 09:15 PM
twowheels's Avatar
Checked two new 250s (one a 2010, the other a 2011) and each registered within a hair of 190 psi nominally dry (only the gas mixture in the cylinder, no additional oil) when new.
Steven Beane #275
afterhourscycle.com
Old 04-25-2011, 10:39 PM
thanks guys i am going to give it a check tommorow
Old 04-27-2011, 02:46 AM
stay_upright's Avatar
My 300 always gave 150 (and runs perfectly FWIW) , I may be tempted to take some base gaskets out to increase this, can anyone tell me where I'd feel the difference in power?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
Old 04-27-2011, 02:36 PM
hannesd hannesd is offline
much more bottom power, more torque! do it!!
Old 04-27-2011, 03:56 PM
stainlesscycle's Avatar
i am only running the thinnest base gasket - bumped my compression up really high....i can only run 110 octane now. not that's a bad thing
07 ec300
www.stainlesscycle.com
Old 04-27-2011, 05:11 PM
Stainless - yes my guess was going to be use the thinnest base gasket as well.
What differences did you notice? Is it better in the wet and dry? Any better starting?
'05 Gas Gas 300
'99 KTM 200
Old 04-27-2011, 06:15 PM
dunno if it's any better - only way i've ever done it (built the motor from 2 parts motors, and only had the thinnest base gasket available when i did it...)
i know this, it pings if i run regular 93. i mix 50/50 110/93 and no pinging. i had already retarded the timing slightly.
it starts first kick everytime and chugs right along. i haven't checked the squish, but my guess is it 's 1.2mm or less...
07 ec300
300 compression stay_upright Enduro Engine - 2 stroke 13 08-27-2009 05:24 PM
125 compression noobi Enduro Engine - 2 stroke 17 04-17-2009 11:07 PM
EC200 compression Bearman Enduro Engine - 2 stroke 8 02-22-2009 04:03 AM
too low compression? welle Enduro Engine - 2 stroke 13 04-02-2008 04:30 PM
Compression low? Wellsy Enduro Engine - 2 stroke 10 11-28-2007 07:05 AM
