Old 01-31-2009, 09:45 AM
nick790's Avatar
nick790 nick790 is offline
Got it all fitted up last night, runs sweet as . No leaks, quite an easy job. What's the norm for running in? 2-3 heat cycles with light use? How much gearbox oil do I want in there, sure someone said less than recomended to stop cluch drag?
Old 01-31-2009, 11:59 AM
darren's Avatar
darren darren is offline
Just a quick heads up not sure if you are goin to or have removed the R/H side casing but recently i rebuilt my EC250 and when i got the gasket kit for it the new side casing gasket was a terrible fit i ended up refitting the old one.
Also brake and clutch cleaner is a good product to break down the watery oil in the gear box. (do not run the engine with it) I filled up the box with it left it for a while and then drained. done that a couple of times it cleaned up a treat.
Old 01-31-2009, 02:38 PM
nick790's Avatar
Thanks, I'm gonna flush it through a couple of times with ATF.
water pump? nhrider Enduro Engine - 2 stroke 17 12-21-2008 12:05 AM
water pump seal skid jackson Enduro Engine - 2 stroke 1 11-14-2008 11:30 AM
Water pump seal brains Enduro Engine - 2 stroke 2 07-26-2007 10:25 PM
Water Pump Seal Removal Tricky Dicky United Kingdom 0 03-18-2007 09:11 AM
removal of water pump seal clangstone Enduro Engine - 2 stroke 1 10-26-2006 11:29 AM
