Old 03-09-2009, 01:58 PM
PBWR450 PBWR450 is offline
Default Unidentified engine/gearbox noise
I finally had a chance this weekend to air out the 01 EC250 I bought last fall. Recent maintenance includes a cylinder replate to A specs with a Vertex piston, bottom con rod side to side clearance was within spec and there appeared to be no up/down play. Clutch has recently started to rattle some at idle, possibly dampers because it goes away when clutch lever pulled in.
Anyway, while at a poker run this weekend part of the course was a good clear uphill section. While climbing this section in 4th gear about 1/2 throttle I began to hear a squeling almost grinding type noise that appeared to be coming from the right side. It immediately went away after dropping the revs. I ran the section again in 3rd gear at the same RPM range and did not hear any noise. I then tried it again in 4th and the noise came back at about the same RPM range as before. Anyone have a clue what may be causing this?
EC300 engine noise fittal Enduro Engine - 2 stroke 6 11-03-2010 09:42 AM
Engine noise roostafish General Discussions & Announcements 11 11-24-2009 12:01 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
Milky gearbox oil juzzasmith Enduro Engine - 2 stroke 10 03-12-2007 05:40 PM
2002 ec 250 Engine noise thingymijig Enduro Engine - 2 stroke 5 02-22-2007 05:08 AM
