#211
Given a quarter turn is around .25mm and is a noticable change in fuelling you might find you don't need to do much and it'll simply wow you more as it cools off I think I ended up at 50.25mm from memory with the 3-1 MR (I'd have to double check the rod). Another thing to note is that its likely that we're all using different fuels, at varying ratios too. Just like always you can never really side by side one persons setting to anothers. |
#212
Yep. Arizona 91 Octane at 50:1 with Maxima.
I also have the 36mm Lectron with the MotoSportz cut. So, if I am comparing 51mm in a 38mm Lectron, who knows? No tweaking and I've yet to do a plug chop. Not like me to avoid data points. |
#213
Now, 10 hours of riding later, I have still not adjusted a thing on it. I have checked the plug, and it looks like it should. Of course I don't know if the carb could have been better adjusted, as I haven't tried to change anything Normally, I would try to adjust it. I'm the type of person who needs to understand how things work and usually like to modify (as in my KYB revalving thread). OTOH, sometimes I just need something simple that just works, as I need to go riding / racing instead of wrenching. I feel the Lectron is such a thing.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
#214
Pulled my new plug after my last ride.
I was a bit nervous that the color would not be to my likings, but not too bad. If anything it may be a bit lean.....???
2012 - XC 300 Racing Seattle, WA |
#216
Looks about perfect for a Lectron. Mine always looks lean too even when it is not. I think the higher atomization makes them look / burn cleaner which is also why people can get 3-6 MPG more and more power.
#217
So I guess my Lectron is now "Broke-in" and ready to RIP!!!! BRAPPPPP
#218
No break in time with Lectron.
#219
I know I was just throwing a little jab / joke in there.....
#220
All looks good Stu. Was that a plug chop at WOT or just a general plug inspection? Oils and fuels used always vary the look of the plug a bit too. As long as its pulling strong and clean its good! |
APT SmartCarb | gasgasman | Enduro Product Reviews | 1424 | 12-29-2017 05:01 PM |
Lectron Carb | singletracker | Enduro Product Reviews | 145 | 07-27-2013 12:20 AM |
APT SmartCarb | siaknijustin | Enduro Product Announcements | 19 | 10-02-2012 08:12 AM |
brushy ride review, bike review, Add on parts review | Mazikeen | SouthEast United States | 6 | 09-04-2012 05:34 PM |
Lectron | Binni | Enduro Intake/Carburetion - 2 stroke | 16 | 03-29-2011 09:44 PM |
