Old 09-15-2023, 02:09 PM
Dario Dario is offline
Default EC300 Cylinder problem
Hi there,
I recently got my cylinder back from coating and rebuild the whole top end. After 5 hours of use the cylinder looked like the first picture. I asked the dude that coated my cylinder what could?ve caused those marks. He told me that the ring clearance was too small and I should get new rings and hone the cylinder. After I sent him the cylinder again to hone it and got new rings I put the ring clearance to 0.4mm on both the top and bottom ring. I rebuild it again, let it run for 3x10 minutes and the cylinder looks like that again. Has anyone on this forum have an idea of where those marks could come from?
File Type: jpg 8E7DC077-A3CA-4261-94EF-664C114FE857.jpg (112.0 KB, 31 views)
File Type: jpg 86F495CD-9ED8-4C39-9F59-D64EDCDD1C80.jpg (125.2 KB, 30 views)
File Type: jpg 4C6416C6-F4D2-4104-B8A1-1A3BF30B30CD.jpg (125.6 KB, 25 views)
Old 09-15-2023, 09:40 PM
What does your piston look like? Do you warm it up properly before going hard on the throttle? 99% of two stroke rings barely need any clearance adjustments if at all.
To me that looks like a cold seizure.
Old 09-15-2023, 10:21 PM
Hmm. If it were me I'd dress the areas with scotchbrite, open the gap to a safe 0.6 and never look inside again.
Old 09-16-2023, 02:03 AM
Like I said, I didn?t give it throttle at all. I just let it idle with some 1/4 throttle in between to warm it up. In the second picture I didn?t even ride the bike. It came just from the idle.
Old 09-16-2023, 02:05 AM
W?ssner recommends 0.29mm for the tip ring and 0,36 for the bottom ring so it should be a safe Gap.
Old 09-16-2023, 02:32 AM
SS109 SS109 is online now
Are you using an A, B, or C piston and what size was the cylinder plated for?
Old 09-16-2023, 04:09 PM
I'm running Wossner and have had jug off after many hours after following ring clearance recommendations with no issue.
But clearly something isn't working. Youd lose no power. But hadn't considered SS109s idea??
Old 09-16-2023, 11:39 PM
Moto7man Moto7man is offline
I have been running a Wossner with 0.4 end gap on top and bottom rings for years. Just an idea but are the numbers on your rings facing upward?
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-18-2023, 08:03 AM
A Piston with Cylidner plated for A Size
Old 09-18-2023, 08:04 AM
Yeah, I made sure the numbers were on top.
Tags
cylinder, piston
ec 300 cylinder problem... knutte112 Enduro Engine - 2 stroke 7 02-17-2014 11:13 AM
problem 2002 ec300 wont rev out? andy176 Enduro Engine - 2 stroke 17 10-07-2013 07:54 PM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
Gear box problem 07 ec300 peterr Enduro Engine - 2 stroke 5 02-26-2007 01:07 AM
