Old 04-01-2019, 01:46 PM
Kuosmane Kuosmane is offline
Unhappy Gas gas ec 125 keeps blowing head gaskets?
My gas gas ec 125 has blown about 3 head gaskets. I have had 2 cylinders and 2 heads , and it has blown the gasket with both. Gasket surfaces are straight and this has happened after full engine rebuild . What could be the problem?
Old 04-01-2019, 03:37 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Can you confirm if you're you tightening both the barrel/cylinder and the head down evenly and down to the specified torque?
You said it's blowing gaskets? As far as I'm aware the cylinder head has 2 'O' rings in it. Do you mean it's blowing one of the 'O' rings? If so, which one?
Old 04-02-2019, 03:14 PM
450exc115 450exc115 is offline
Are you setting the number of base gaskets to ensure the transfer port line up with or are above the piston at TDC? After that you need to check he squish on the head to make sure it is in spec.
Old 04-02-2019, 11:34 PM
Elvis74 Elvis74 is offline
Which squish do you have?
Gesendet von iPhone mit Tapatalk
Old 05-12-2019, 12:54 PM
Default Problem solved
My ignition was too advanced. After i set it to 1mm btdc it stopped blowing inner headgasket
Old 05-12-2019, 12:57 PM
Davehuge's Avatar
Great to hear you found the problem and thanks for letting us know.
2018 Head o ring gaskets dzhitshard Enduro Engine - 2 stroke 4 02-15-2019 10:16 AM
gas gas ec 300 2015 blowing fuses! Munch Enduro Engine - 2 stroke 3 07-07-2017 10:14 PM
Re-use head gaskets/o-rings? Terrence R Enduro Engine - 2 stroke 6 04-01-2016 06:15 PM
Head gaskets, what's the trick? GGRider01 Enduro Engine - 2 stroke 9 10-11-2015 12:19 AM
