2001 Ec300 Does It Have A Top End? New To Gas Gas
I'm so glad I found this site. I just purchased a lightly used 2001 Gas Gas EC300. It has great compression, unbelievable bottom end and midrange. However, when it hits the topend portion of the powerband it hits a wall. It just doesn't pull, it only revs. I've had Japanese 250T's with low to mid power, but they still had a topend pull. All the reviews I've read talk about it's linear power. I agree with that, until I think about the top end. Is there anything that this could be, Powervalve or something??? Is this normal going from a Japanese 2T to a Gas Gas. By the way, these bikes are incredible for technical and trail riding.
I appreciate any input you can give me. I've got no one else to ask. |
What pipe are the you running? The Gnarly signs off early but provides lots of bottom. Other than that, jetting as usual can have a big effect as can tired reeds. Might be worth checking base gaskets - often people go thin for bottom end. It's a fairly well balanced engine and if there's no faults should provide plenty of top but you can apply a whole load of tweaks to adjust the power characteristics - pipe, reeds, jetting, base gaskets, flywheel, timing, PV cover, end can etc. Naturally check for faults first. I'm not the best person to advise on this though as I don't need top end for my riding.
I think Ian hit the nail squarely on the head - I had an '01 and the gnarly pipe on the bike focuses power low to mid. Find a doma or a messico pipe - newer pipes don't fit (but you might be able to "make it fit"...) I forget which years will fit your bike.
Also remove the PV cover and check to make sure it's not full of goo. Clean the power valve assembly and make sure it's operating properly. Matt R. did a great update to a PV disassembly instruction that can be found in the technical section of the website here. jeff |
The lack of rev on the 300 is just; the nature of the beast; there is nothing that you can do to make any tangable differances to make it behave like a 250, changing pipes will make a subtle but not dramatic change. Gear it for your terrain and ride it like an open bike , which it what it is.
My '06 EC300 pulls strong to 9700 RPM with the stock GG pipe. That is excellent for a 300 in my book. The engine provides very linear power over a very broad range.
My '01 XC300 with a Doma pipe runs like my ’06 EC300 with the stock GG pipe – linear power with great top end power. My ’01 XC300 with a FMF Gnarly would not rev nearly as high or produce as much top end power. For comparison, I ran the FMF and Doma pipes on the same hill with my ’01 XC300. The Gnarly pipe would pull the hill in 3rd gear with moderately high RPM while the Doma pipe would pull the hill screaming in 4th gear. That is a pretty substantial power difference to me. Both runs were in dry conditions with a trials tire so there was little wheelspin. With the Doma I didn’t notice any loss of low end power compared to the FMF, it was just more controllable.
Thanks Ian, Jeff, Widebear, and Erik.
I've got a stock Gas Gas pipe. It does have a 1/2 inch deep ding in it, I don't know how much that will effect the power. From all of your posts, I'm thinking it probably is the powervalve and jetting. From what Eric was saying, I should be getting a more linear progression of power through the top end, instead of it just signing off after the midrange. If you guys think the ding in the pipe is a big deal, and my jetting isn't the LTR set up, I might just get that Power package that has the Doma pipe etc. How much difference does that Power Valve Cover from LTR & their jetting kit make? Also, will aftermarket reeds make a big difference? If so, what brand is best? |
2001 EC300 won't idle - can't get jetting right | bexi | Enduro Intake/Carburetion - 2 stroke | 16 | 03-04-2010 10:30 PM |
07 Plastics on 2001 ec300 | johns2394 | Enduro Chassis & Body | 5 | 04-04-2009 07:17 PM |
Gas Gas EC300 2001 Supermoto maybe | johns2394 | Enduro Chassis & Body | 12 | 01-29-2009 07:58 AM |
2000 XC250 CDI for a 2001 UK EC300 | krazy | Enduro Electrical & Wiring | 1 | 09-14-2008 04:58 PM |
