Old 08-25-2019, 12:02 PM
Banditpowdercoat Banditpowdercoat is offline
Default How often do you change jetting?
Just wondering how often you guys change jetting for temps and such?
I ride same few areas around my house. 1000' up to 7000' elevations. And from damp, 5*c days to 32*c I know I am fat jetted, she runs good, and I mostly am single track/ old overgrown horse logging roads in the BC Rocky Mountians. I haven't changed my jetting, and know previous owner never changed for seasons or temps. SHe is a 98 ec250 with PWK 38. My idle sure does change with elevation and engine temp tho. And the idle stop screw is all the way in. I have to take carb out and record the needles one day.
It's a 1998 EC250
But surely you guys are not taking carb out every day you ride to change?
Old 08-25-2019, 12:33 PM
Ps. My present setting. Not sure if I should change anything?
Idle stop almost bottomed
Pilot 35
Mix screw 1.5 turns
Main 178
Needle N1EC
Clip 3
Old 08-25-2019, 02:59 PM
Davehuge's Avatar
Davehuge Davehuge is offline
[QUOTE=Banditpowdercoat;191691]Ps. My present setting. Not sure if I should change anything?
What bike and what year is that?
All the best, Dave.
Old 08-25-2019, 03:57 PM
It's possible that you have an internal gasket failure in the carb.
You should not have to change your jetting that much.
Old 08-25-2019, 05:03 PM
[QUOTE=Davehuge;191692]
All the best, Dave.
Sorry, forgot that. It's a 1998 EC250..
It runs great, no issues other than it smokes a lot (50:1 Interceptor) and plug always rich black.
Old 08-25-2019, 08:27 PM
That n1ec is your smoking and rich black plug issue.
Old 08-25-2019, 09:08 PM
WHat should I look for to put in?
Old 08-25-2019, 09:48 PM
Depending on which 38mm keihin you have fitted it varies. If it is the old round screw cap style I liked the n3eg with a 42/45 and a 178/180 main.
If it is the later two screw cap I?d run the nedw with 42 and a 178. You might need a size either way for your altitude, but once you have it set nice you?ll rarely have to do much other than a tweak of the air screw.
Old 08-25-2019, 10:03 PM
Cool thx, It's the older round screw AS1 carb I'll have to google the n3eg for a source.
'03 450 FSE oil change raoufhakam Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-26-2016 03:53 AM
'05 450 FSE Oil Change... bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-20-2016 01:30 PM
Quick reassurance - elevation jetting change liv2day Enduro Intake/Carburetion - 2 stroke 8 05-02-2014 12:34 AM
Oil change Vinny Enduro Engine 4 stroke (including EFI & Exhaust) 7 05-25-2011 09:37 PM
Jetting Change f14rio Enduro Intake/Carburetion - 2 stroke 12 05-02-2010 08:12 AM
