#31
Firstly there is no way of knowing what position the carb should be in, normally on other bikes i have owned there is a notch in the boot that lines up with a nib on the carb, but none on the GG - so i just lined the seam on the boot up with the screw at the center of the carb I also noticed that the boot is a bit warped, it was impossible for me to get the boot to fit properly around the carb
#32
Our weather is getting significantly warmer. What was OK at 30 degrees F is making the plug black at 45. The bike still seems to be strong across the powerband though. |
#33
Digging this back up.
My 2011 sixdays 300 has a 36mm carb . Was anything ever resolved about some having 38's (as the spec sheet says) and some having 36's ? |
#34
I wonder if the six day bikes have 36's and the xc and race versions have the 38's just a thought. But what will the nambotin have? Or the cervantes replica?
#35
Better to not try to over-think this. Some have 36s, some have 38s. You don't know until you open the crate and look inside. That said, all of the 2011 bikes I've checked have had 38s with handlebar mounted choke actuation.
#36
Nope , there is no rhyme or reason to it . Me & jeff both have six days one has a 36mm one has a 38 both have handlebar chokes.
300 2T Differences between 08' and 2011 ?? | husley | General Discussions & Announcements | 11 | 12-23-2010 10:31 AM |
´08 and ´09 differences? | vavido | General Discussions & Announcements | 3 | 11-10-2008 09:20 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 05-12-2008 01:02 AM |
head differences 03-05 450? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 05-03-2008 07:43 PM |
Differences between DE and EC models | ScottyR | General Discussions & Announcements | 38 | 02-13-2007 06:40 PM |
