2012 EC 300E CLUTCH COVER leaking!
Has anyone had their clutch cover gasket leak? Is a Rekluse cover the solution? or will a new gasket sort it for a while? I see lots of people put a new cover on, but is it the gasket that fails or is the plastic cover not up to the job?
Any help will be welcome from here in the uk! cheers people. |
Rekluse one's are great. But I too still had a very small leak. I then read compared the OEM to the Rekluse. Where the bolts go through the Rekluse the thickness is less then the OEM, therefore causing the bolts to bottom out in the engine case. 2 options here is to either put a washer on the bolts or use shorter bolts. I used the the shorter bolt method. NO LEAKS!!!!
2012 - XC 300 Racing Seattle, WA |
Thanks for the reply! Have found a uk website that do Gasser Rekluse covers so will get one ordered up when i get paid next month and sort out some shorter bolts.
Thanks. |
I got a used rekluse cover off of ebay, fixed.
I'm having the same problem on mine right now, i'm going to have to find a new cover.
Sent from my iPhone using Tapatalk |
Make sure bolts arent bottoming first. They cut it very close. ie too long by one or two threads.
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
Thanks bkwdc, I'll check that first.
Correct I believe it is the top long bolt that is a couple threads to long.
Mine was the shorter one on the left. Drove me a bit crazy.
Mine went right on, no leaks. Now everyone thinks I have a cheater clutch
1 2012 300E & 1 2013 300E brand new | Mo.man | New Bikes | 0 | 05-22-2013 10:28 PM |
2012 clutch cover cross over ? | motogroove | Enduro Engine - 2 stroke | 3 | 09-27-2011 09:06 AM |
RMW Clutch Cover | Rod Overstreet | Enduro Product Reviews | 2 | 01-24-2011 10:51 AM |
