#21
Bike was not ridden hard for less than 30hrs...... still think I need to check?
How could the PV be adjusted incorrectly? Had my 10' 300 apart last year and I don't remember detecting that I could adjust the PV? J
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public Last edited by husley; 12-31-2014 at 03:34 AM. |
#22
Piston and ring should be fine then you'd think? I missed the bit about the low hours.
The power valve assembly can have some play in it. They're very easy to check and adjust, there's a couple of good tech articles on here inc. videos. If they're not adjusted right you can get a bit of a flat spot down low. I did on my 200 anyway.
2005 Gasgas EC200, 1987 Honda CR125, 1981 Suzuki PE175, 1976 Yamaha YZ125, 1975 Suzuki RL250 |
#23
Good overall gearing for tighter trail up from stock gearing of 12/48 If you don't need the top speed you could add a few more teeth.
15 GASGAS EC 250 19 Sherco SE 125R |
#24
Its more of, does it have the proper tension/preload.
2006 Gas Gas EC250 2011 Husaberg FE390 |
#25
Thanks!
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public |
#26
If I remember correctly at some point GasGas went to a different pipe (different from the 250 &300) for the 200. Seems like it had a longer head pipe to raise bottom end power in the same way an oversize power valve cover does.
#27
At some point over the last few days and many threads I read the same. I think I remember 02' +- being the cut off. So, my question is: Could I just add a spacer in between the pipe and flange to replicate a longer head pipe?
Thread Tools | |
Display Modes | |
does anyone make a big bore kit? | seamonster | Enduro Engine - 2 stroke | 9 | 01-21-2012 09:05 PM |
The Pro's Make It Look So Easy | Rick | Pictures & Videos | 1 | 12-04-2011 10:49 PM |
How to make gaskets | Rabbitist | Enduro Engine - 2 stroke | 5 | 09-17-2011 07:46 PM |
Do they make FMF SST | gasser250sm | Enduro Engine - 2 stroke | 1 | 12-26-2008 10:16 AM |
If we make it... would you buy it? | Steve@Motowest | GasGas Member Polls | 12 | 07-09-2008 01:15 AM |
