Old 06-25-2011, 09:07 PM
Woodsknight Woodsknight is offline
Default Air filter access on electric start 2stroke's
It is hidious and GasGas should be ashamed to let the E-start 2strokes leave the factory like that. Im pissed evertime i have to do a filter. Not to mention i am blowing through filters that are tearing a tiny cut on top. I now know that it is the seat doing it and not the cage during installation. Originally i thought i was cutting the filters during installation because the fit is that tight!!!! And for anyone that has not done an air filter on an E start 2strone, i am not being dramatic about it. Gasgas welded a bracket in between the top subframe rails towards the rear fender. The battery sits in this bracket. Problem is that the battery bracket takes up almost all the normal area that u would use to intall the air filter. So now u only have a small square hole to squeeze the filter in and install it. I am disgusted with this area of maintaining the bike. I am considering looking into some type of way to modify the left side panel/airbox so that i can install the filter from the left side directly into the bike. Im thinking that with the right hardware and some careful cutting i could make some sort of hinged door with dzuz fasteners to do filter changes. I have trimmed my seat and i am hoping that the filters will not get the slit cut in them anymore. Ok ok u guys listened to me rant........now what do u suggest?
2011 EC300e
Old 06-25-2011, 09:38 PM
Fair call bloke..
Mines not even got a battery in the airbox and its by far the hardest air filter I've ever had to install. The frame/filter setup offers some good sealing, but the lugs are challenging to locate at times. The angles etc to drop it in and get it on is an aquired skill. And just like you, my seat manages to eat a filter every 800kms even with me being cautious. Each filter change I take a bit more material off the seat hoping to find the magic point.
My seat cover has torn open on the bottom front edge where it meets the tank shroud, and my kick starter has sheered off. My rear brake hose chewed out part of the engine case.
I'm still happy with the bike, but I must say, I have had more issues and parts replaced under warranty with this bike than I did with my WR250F with 13,000kms on it.
Its fair to say Gas Gas is moving forward with refinements, but theres still room for improvement. I'd still buy another one though.. Everytime I ride it, it reminds me why I loves it!
Old 06-26-2011, 08:53 AM
Bailey28 Bailey28 is offline
I don't have the electric start... However I recall cursing at the filter after installing it in a KDX200.... The GG is a little easier. With the KDX, most of your filter oil ended up sqeezed out onto the frame and airbox surfaces. Oh, Jakobi, 42 pilot, NOZH, 160 main, 1 1/2 out on air screw ROCKS!
'10 EC300 -- very happy
Old 06-26-2011, 07:20 PM
Thats mighty lean on the main Bailey
NOZ and N1E are the same with NOZ being a half clip richer.. What clip you running the needle on?? I'm definately trying the N3EW after the head work, and may try the NOZI aswell.. So far N3CH #2 has been my best setup.
As for air filter access nothing is really perfect. The WR access through the side cover works well but can still leave doubt as to whether its located properly on the far side..
If you removed one of the side mount bolts and exchanged it for a quick release you might be able to tear the whole side off easy enough.
Old 06-26-2011, 10:10 PM
rgranger's Avatar
rgranger rgranger is offline
quick release like a dzus or something else?
Rob Granger / Katy, TX EC300
Old 06-27-2011, 01:56 AM
Dzus quarter-turn fasteners
Old 06-27-2011, 09:04 AM
mcnut's Avatar
mcnut mcnut is offline
Fair call bloke..
Obviously you've never changed the air filter on a Honda CRF250X.
Old 06-27-2011, 11:37 AM
Neil E. Neil E. is offline
You guys are nuts trying to change the filter through the top. Remove the left side cover!
I removed the plastic rivet thing and put a threaded insert in the frame. I just take out my new screw and the fender/side cover screw. The rear fender stays in place. I flex the rear fender enough to slide the left side cover off.
If you want to rant about something, the right side cover is it! The way it overlaps the rear fender is stupid! The rear fender has to move out a half inch minimum to let the side cover come off. Totally retarded design!
I'm not a racer; I can see how a quick change would be more important to them.
Old 06-27-2011, 05:08 PM
rgranger's Avatar
I think that i have a few from the ducati, I will have to try to see if I can get it working, thanks for the idea.
Old 06-27-2011, 06:49 PM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
I put a turn tech battery in my 07 300 and couldn't decide where to mount the battery.
I ended up drilling 4 holes in the seat base and threading some cable ties through.
The battery is light, is cable tied to the base of the seat and gives me no probs but all the room I would normally have for air filter changes.
I have the battery hard wired and therefore have another cable tie in a loop which hangs the seat off the right side of the bike whilst changing filters.You could always make a plug connection too.
Cheers Mark
Changing Electric start to two kill buttons Woodsknight Enduro Electrical & Wiring 4 03-19-2011 10:28 AM
New 2011 Gas Gas EC 300 (Electric Start) onegreyghost General Discussions & Announcements 32 08-31-2010 07:23 PM
GGOR Questions : 2T Electric Start Specs & Direct Injection Neil E. General Discussions & Announcements 18 08-28-2010 09:54 AM
electric start 2 Banger Gas Gas Klausen Enduro Engine - 2 stroke 1 06-21-2010 06:19 PM
Electric Start EC300 J D General Discussions & Announcements 25 02-22-2010 03:12 PM
