clutch not progressive..
my clutch feels kinda grabby. it's hard to slip progressively. i know the plates (both steel and friction) are close to the bottom of their wear limit. the basket is not notched. i've bled the slave, and rebuilt the master. i'm gonna try mixing some other plates in to achieve a taller stack height... i'm assuming the plates are worn enough that it's just reaching the end of it's service limit...i run klotz flexdrive 30. clutch does not drag... any other suggestions??
I am having the same problems with my 06 EC300 that I just bought. The 02 I just sold and my sons 250 has a much better feel. Keep us posted as to what you figure out.
2006 EC300, 2000 XR650R, 2003 EC250, 2001 EC200 (OK, the last two are really my sons). |
as soon as my new (to me) clutch shows up i'll mix and match and see if it's a stack height issue.... i know the plates (both friction and steels) were right at bottom of service limit and that springs were good. if i can achieve even .5mm taller stack it'll probably feel better. hopefully..
I was looking at clutch plates for the bike and noticed that Barnetts gives the same part number for GG as a lot of late model KTM big bikes and ATV like the 450 SX and . This would be much easier to locate. Anyone know anything about this? It is not in the crossover section.
haven't checked to see if barnett's plates for the gg are the same as ktm.. i guess you could call them up and ask....if you do call them, let me know.... i still should get new plates..
as for my grabby clutch issue, it was worn plates. both frictions and steels were at the very end of service limit. i mixed the thickest plates from 2 different clutches together and now it's perfect... |
http://www.barnettclutches.com/searc...n=301-48-10001
that's what mine would do, i'd have to rev to the moon and drop the clutch. sucked.
both slave and master were rebuilt. i only run klotz flexdrive in it. the problem was definitely worn plates.
Ok as long as it's working but for the future if you have worn cylinders either slave or master then a rebuild kit wont work. At least it didn't for me as the actual bore was worn causing the piston to stick a little.
