Won't Idle in Gear
I HAVE read a bunch of post on this forum and others about this. But can't seem to get a clear understanding of what might be the issue.
Would like a little help to eliminate what it might or might not be. This is what I have happening. Idles good in N, pull clutch shift into first, idles for 5-10 seconds then bogs down and dies unless I blip the throttle. I have watched several youtube videos on proper hydro clutch adjustments, I have done so. The bike is even hard to roll/push when in gear and clutch pulled in. I checked the fluid, it is dark but not black and is half way full in the M/C. I'm going to get fresh DOT 4 and bleed it to see if that is the issue, I don't think it is, but will do it anyways as an excuse for maintenance, that looks like hasn't been done on this bike. The more I tear into it, the more little issues I am seeing with it. Oh well, I'll just call this the Stupid Tax for learning a new hobby. Sorry, I'm new to these, learning as I go. Please be patient till I figure this stuff out. |
What year bike? You should use dot oils in most clutches. I use atf in mine. If it's an old bike it's likely the clutch fins have notched, either replace or file. I replaced my basket with a Barnett, it is beautiful!!
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
I have DOT 3 for the brakes, brand new M/C and lever. Bleed just fine. The engine idled after about 15 minutes of riding. So maybe I just didn't let it worm up enough earlier today. I put Walmart ATF in the gear case, which I have read some positive reviews about, on here and other forums. One thing I noticed, I need to build my clutch fingers up, only using two fingers, now my arm is tired after only 15 minutes of riding.....wow, can we say out of shape! Once this clutch drops, I'm going to get new plates and inspect the basket. Hoping it is fine with just a touch up and a file. But if not, then Barnett it is, seen some good reviews with them also. |
It calls for DOT 4, in a pinch could I use DOT 3 till I get to town to get some DOT 4? I live 20 miles from town. |
Double check the MC for the clutch before you hook in. Some take mineral oil, others brake fluid. Not interchangeable.
Both of my Gassers have a bit of clutch drag (and have from new). Most noticeable with fresh oil and a cold engine. It's not to the extent that it makes the bike hard to start in gear, or that the bike will try and lurch forward with throttle and the clutch pulled, but is enough friction to drop the revs down a tad. I don't expect my bike to idle in gear excessively though either. If it's in gear I intend on keeping the bike moving. If I'm stopped I usually kill the engine. If I stall down a hill a quick bump brings it back to life. These engines are easy enough to live with once you get them set up. I can bump the idle up to counter act the stalling out, but I don't like the way the engine feels and responds with a higher idle, particularly while trailing revs with a closed throttle. |
Check the inner basket for wear too. But why would you idle it in gear for any time?
Plus it is ridiculous to get into N after the bike is running. With its off, it pops right into N but when it is running not so much. |
Wanted!! Ec200 seat, radiators, switch gear, gear lever | Kendog | "Wanted to Buy" & "Want To Trade" | 2 | 10-12-2014 03:12 PM |
02 400 will not idle | jason r | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 11-18-2013 04:14 PM |
Bad idle | Madhead | Enduro Intake/Carburetion - 2 stroke | 1 | 08-11-2011 06:20 AM |
Does not idle or rev | Binni | Enduro Intake/Carburetion - 2 stroke | 8 | 02-14-2011 03:29 PM |
can,t get idle up | geno | Enduro Intake/Carburetion - 2 stroke | 1 | 04-18-2010 08:49 PM |
