Old 12-11-2009, 07:39 AM
stainlesscycle's Avatar
Default clutch basket mod
i tore my basket apart and found 2 rivets missing... so i removed all the rivets, and am hoping to tap the basket and run the bolts in from the backside. or do i tap the thin plate and run flat sockets/ovals in from the inside of the basket (seems awfully thin, don't know if bolts will let go...)? is there clearance issues with the button heads hitting kicker intermediate gear underload? (there's aprrox. 3mm clearance between button heads and intermediate gear static, not sure if there's any 'wobble/deflection under load...'
anyone done this???
Old 12-11-2009, 09:15 AM
welp, i tapped the basket and ran some m5 buttons in it. we'll see how it works.
Old 12-11-2009, 10:00 AM
works fine for my zip around the yard. ohh and you know that sound that you think is your pv? and it only happens when you lug the motor? well in my case it was the basket rattling around from loose rivets on the clutch cush drive.. noise gone. nice.
Old 12-14-2009, 06:08 PM
mxdj2003 mxdj2003 is offline
im glad you got it together,i did this mod to my clutch a year ago and havent had any issues
Old 02-09-2010, 08:36 AM
jriley43's Avatar
jriley43 jriley43 is offline
what length was your m5s
Old 02-09-2010, 10:12 AM
i can't rememember the length now, sorry. 5x14 or so i'm guessing.
Clutch Basket Crossover eff Enduro Engine - 2 stroke 13 03-07-2010 07:37 PM
Clutch Basket jriley43 Enduro Engine - 2 stroke 2 03-10-2009 02:12 PM
125 clutch basket GasGas Enduro Engine - 2 stroke 1 09-08-2008 10:46 PM
