Tachometer problem....Help
Hello! I am Brazilian and this is my first post here.
I have a gasgas EC300 2010 and bought now, and I have a problem. I bought this bike and the tachometer was not working(not connected). I connected the speedometer direct in wire coil, but she gets marking more than normal, at idle it is marking 8000 rpm. You know what can it be? has anything on this wire is connected or direct it? Thank you and sorry my bad english |
You may have it connected incorrectly (... which is why you posted here DOH!)
The speedo did not come with the rev counter standard. It required adding a special cable down to the spark plug I am using my
... phone so I cannot google. But the gasgas computer/speedo is a Trailtech computer so google that for installation proceedure
Thank You swazi_matt. I will try it.....
Have a GG but I might have a problem | drdfblackm | General Discussions & Announcements | 20 | 12-17-2013 06:42 PM |
I bought a 2000 xc and keep finding problem after problem | 675AZ | Enduro Engine - 2 stroke | 12 | 02-15-2013 07:25 PM |
EC 300 problem!!!!!!!! | clerky clerk | Enduro Engine - 2 stroke | 31 | 07-06-2011 05:19 PM |
And then this became a problem. | dank | Enduro Engine - 2 stroke | 9 | 03-22-2010 07:58 AM |
50 boy problem | Sharpie | Mini Gasser 's Corner | 3 | 09-04-2008 03:58 AM |
