Old 02-07-2022, 04:23 PM
Jcvd30 Jcvd30 is offline
Default How Much ML Gearbox Oil Gas Gas EC 250 ( 300 ) 1999
Hy guys ,
Need some help. i Bought a GRO GEAR TRANS 10W40 to change the gearbox oil but my doubt is how much oil to put ? read some people say that is 900ml but want to be sure that is that value.
Cant find my bike Datasheet.
Thanks a lot
Old 02-07-2022, 07:25 PM
Gasser Nate's Avatar
Yep 900ml is correct
Old 02-08-2022, 05:17 AM
ok thanks . you know if is any place near gearbox to see the oil level ?
Old 02-08-2022, 10:27 AM
Zman's Avatar
Zman Zman is offline
Yes the sight glass on the clutch cover will show you, but you need to give it some time for the oil to flow into the window and you may need to tip it to the right to get out air bubbles if the oil is not warm.
Old 02-08-2022, 01:49 PM
but beware, the sight glass can often look full on some models. think the design traps oil, but 900mm is right
2003 txt250 Pro
2013 Ossa 280i
Old 02-08-2022, 07:30 PM
gasgasman's Avatar
The sight glass is to monitor oil quality, not quantity.
I've been using a full quart of oil in all my GasGas'.
Old 02-09-2022, 05:49 AM
ok thanks for the information. i put 900 ml, its a little bit challenging process the access is not very good. but start the bike and get a little ride and everything was ok .
Old 02-09-2022, 01:34 PM
FYI when the bike is delivered from the factory it comes with about 150ml of oil in it. the dealer will drain this and fill it as part of the put-together process.
When i got my 2010 i got it from the wholesaler in the crate, he included a litre and told me there was usually very little oil in it from the factory. I put the bike together, looked at the sight glass and could see oil so went and ran it in. It did make some funny noises lol
I replaced the oil and was wondering where the rest of the oil was (oops!) anyway the clutch and gearbox was still perfect when i sold it with about 400hrs of hard enduro type riding
2003 txt250 Pro
2013 Ossa 280i
Old 02-10-2022, 04:11 PM
farmerj's Avatar
farmerj farmerj is offline
Re: access, lean your bike over onto a work bench (or against a wall) so that it is resting on the end of the handlebar.
Put a funnel in the oil filler opening, and pour away. Because your bike is leaning at an angle, the funnel is almost vertical or "straight up".
Works good for me!
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 02-11-2022, 09:14 AM
Works good for me!
Jeff
Yes next time gona do that, normal position is very hard to control the oil to the filter
2002 gearbox fit a 1999 bike? Munch Enduro Engine - 2 stroke 2 09-21-2020 02:23 AM
Gearbox oil 2stroke Jinx_pt Enduro Product Reviews 10 06-23-2020 01:07 PM
Gearbox Oil About RomeoMustNotDie Enduro Engine - 2 stroke 23 03-08-2017 08:32 PM
Gearbox oil 10 40? Capz85 Enduro Engine - 2 stroke 4 05-24-2015 08:59 AM
Gearbox oil eviljim Enduro Engine - 2 stroke 37 06-07-2014 01:34 AM
