Flywheel nut question
I bought an 03 EC 250 Dealer Edition a year or so ago and have ridden the heck out of it since. This was my first real enduro bike, and now that I'm getting faster, I think I want a little more snap. I opened up my ignition cover yesterday and to my surprise, there was a FWW added by the previous owner. I thought everything was stock. I took the weight off, and I want to try the bike this way, as I am sure it will liven it up. The problem is that I don't have a nut to put back on the crank bolt. Does this matter? It this nut a special piece? It appears the nut would have threads on the outside and on the inside to thread on to the crank bolt. I also am guessing that I will need a thin walled socket (FWW took a 22mm) to get it tight. Any help would be great.
Well you DO obviously have to have a nut on there.
The stock flywheel nut is just a flanged nut, maybe hardened, maybe special threads. Quote:
I'm sure Go Fasters can send you a flywheel nut pronto, and a standard socket should work just fine.
Ross '05 MC 250 '91 Husky 610wxe '04 Duc M800 R.I.P '06 Duc S2r 1000 R.I.P '07 Duc S2r 1000 still rubber side down... ---------------------------------------------------------- May be so... May be not so... My Website |
Like Ross said you need a nut ontheir. I would take your flywheel down to your local hardware suppplier and have them find a regular nut to use should be no big deal, or order one from GF.
Paul B |
Thanks Guys,
I took the FWW to the local Hardware store and found the details. It is a 12mm with a 1.25 pitch. They had regular hex and lock nuts, but no flanged nuts. Do you think it matters if it is a flanged nut or can I just use one of the others? |
Order yourself the correct nut but in the meantime a regular nut WITH a washer and a dab of blue locktite should be ok IMO. Just change it when you get the new one.
Skidad in MA |
Flywheel Removal | BOBBYPRUIETT | Enduro Engine - 2 stroke | 3 | 04-08-2010 12:16 AM |
flywheel weight ? | GAKLX | Enduro Engine - 2 stroke | 17 | 11-10-2008 09:01 AM |
Flywheel Spacer | GAKLX | Enduro Engine - 2 stroke | 0 | 10-12-2008 05:32 PM |
DE and EC flywheel weight | GregM | Enduro Engine - 2 stroke | 11 | 05-20-2008 04:46 AM |
What's up with this flywheel nut? | rpduc | Enduro Electrical & Wiring | 5 | 03-21-2008 07:47 AM |
