Old 06-06-2011, 05:51 AM
Rabbitist Rabbitist is offline
Cheers lads the seal should be here tomorrow ill let you know how i get on
Old 06-06-2011, 08:02 AM
GMP's Avatar
GMP GMP is offline
You don't need to touch the water pump to remove the primary cover, just the relative common bolts to the water pump cover. Just drain the coolant. You do need to pull the clutch.
Old 06-06-2011, 10:53 AM
So is it possible to remove the old one and replace it without having to take other things off?
Old 06-06-2011, 10:58 AM
stainlesscycle's Avatar
it can be done, but it is difficult to get the new one in square and seated. if it's not square and seated, it will leak.
07 ec300
www.stainlesscycle.com
Old 06-06-2011, 12:45 PM
Brilliant cheers may turn up a little bit of nylon at work to knock it in square..
fse 450 br(e)ake lever $52?!! T.Low General Discussions & Announcements 4 09-22-2009 07:25 PM
Gear Lever crossover? Leo Enduro Chassis & Body 13 04-17-2009 04:23 AM
Crank Seal kim Enduro Engine - 2 stroke 2 05-18-2008 09:41 PM
Gear lever length ???? pyroman General Discussions & Announcements 3 05-16-2007 07:59 AM
00 GasGas EC300 Gear Lever Gasser370 Enduro Engine - 2 stroke 20 03-27-2007 10:19 PM
