Part ID??
I'm putting my 97" back together and have found this piece. I do not recognize it and can't find it in the parts microfiche. This was in a box that my mechanic handed me after they had split the cases for me. It is just bigger than a quarter.
looks like the spacer that goes over the front sproket drive shaft, and SEALS the gearbox....
pull off the front sproket and check beween the seal and driveshaft. |
Ah, you are correct. Thank you. Are there o-rings that go on the inside of this?
Yes there are.
yep, mine had 2 o rings, one in the groove in the spacer, the other just behind it on the shaft. not sure if thats how its supposed to be, but everything lines up perfectly on mine....
Thats correct. Without the proper fit and seal between the collar and shaft, oil will leak out (and worse, water in) between the collar and shaft.
Thread Tools | |
Display Modes | |
Fse Part , What is it , and where is it from ??? | Gerko | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 02-06-2011 07:12 PM |
To part it or not? | PEB | General Discussions & Announcements | 2 | 10-02-2008 05:03 PM |
