Old 12-15-2019, 09:31 AM
GG221 GG221 is offline
Default Estart delete
I?m tired of chasing demons with this starter. Had it working perfectly, now it?s not. So I?m tired of spending time and energy chasing this thing in circles when the kick starter will work in one kick every single time. So...
I need a stator cover that doesn?t have a bendix cover also. Will the stator cover for a 2015-2017 fit?
Can I remove the battery ?
The big gear outside of the stator that the bendix gear hooks up to...can that be removed or is it needed for weight distribution?
Anybody want to buy a starter?
Old 12-15-2019, 10:34 AM
Yes, can be done.
Just buy the cover from the bike without the e-start.
Pinion gear is bolted on.
Old 12-15-2019, 10:40 AM
Battery will not be needed with estart gone, correct?
I was wondering if the weight of the pinion gear is needed to balance the stator or if it?s fine to just remove it.
Old 12-15-2019, 11:11 AM
The battery is not needed for the bike to run.
Removing the pinion won't affect the flywheel balance.
Old 12-15-2019, 05:21 PM
I have a cover and a capacitor off a 2014 on motor that will suit but I am in Australia. Where are you?
Old 12-22-2019, 10:48 AM
I?m in the US. So I will need to add a capacitor because of removing the battery?
Old 12-22-2019, 12:02 PM
Anders Anders is offline
Yes, my 2015 without estart has one
Old 12-22-2019, 11:14 PM
You will need to remove the gear for clearance with the new cover.
Old 12-23-2019, 12:02 AM
No it is not needed to run the bike. I have run mine several times with no battery while I was waiting for my new battery to arrive.
Old 10-03-2020, 11:50 AM
sigasgassi sigasgassi is offline
what capacitator do you have on your bike? i would like to remove the battery to save some weight
2018 Starter Delete nhgas Enduro Electrical & Wiring 1 11-10-2017 07:58 PM
Let's Delete! mcnut Parts 10 03-24-2015 05:02 PM
Lights controll Estart - vs Non-Estart loom stian Enduro Electrical & Wiring 11 07-22-2014 02:41 PM
what is eta of 300 estart nmrider General Discussions & Announcements 87 05-11-2012 03:10 PM
Delete Thread Icon in message edit window. REVERUP Suggestion Box 4 02-03-2010 06:36 PM
