Racing wiring harness for my 2017 EC300?
The bike: 2017 Gas Gas EC 300 (North American version)
Hey, just wondering if anyone has some information on how to eliminate the keys you turn on before hitting the elec. start button. Also wouldn't mind losing the chunky start/kill/turn sig. switch cluster. Just curious if there is a racing wiring harness for these bikes that cleans up and simplifies the dash. Thanks!!! |
However, you can of course build your own. On my (kick start only) 2015 EC200, I have reduced the handlebar harness to just one kill switch. The switches for light and heated grips I have placed above the headlight, to protect it from crash damage. I have removed the tail light, speedometer, stop light switches etc, but I have not cut the harness anywhere. I have either just removed some part (at a connector) or made new parts (using compatible connectors).
But it's up to you to check that :-)
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc Last edited by Anders; 10-23-2017 at 09:13 AM. |
Wanted 05 FSE 450 wiring harness | chaddlez | Parts | 1 | 12-21-2015 06:51 AM |
Wiring Harness | mikeh | "Wanted to Buy" & "Want To Trade" | 1 | 08-24-2014 04:01 PM |
For Sale: Wiring Harness | F_G | Parts | 0 | 05-26-2014 05:29 PM |
