Old 04-18-2018, 09:32 AM
Mikeyx Mikeyx is offline
Default Muffler issue
My bike is 2009 EC300 Racing. The muffler rivets do not last long...
Are the muffler bolts supposed to be left loose or wound in tight? Any other pointers, please?
Old 04-18-2018, 09:42 AM
Anders Anders is offline
Muffler bolts should be tight.
Old 04-18-2018, 09:48 AM
Thanks.
I've had them tight. Just wanted to be sure since the nuts are nylocks...
Old 04-19-2018, 03:28 AM
RBrider's Avatar
RBrider RBrider is offline
Thanks.
Are the rubber inserts and sleeves intact?
RB
Old 04-19-2018, 07:11 AM
I guess they were okay last time I riveted and installed the muffler. I did not notice any greater misalignment (no need to deflect the muffler to be able to insert the bolts).
The bike is still in winter storage; most probably I'll take it out one of these days and will check the rubber parts. I'll let you know.
Old 04-20-2018, 11:30 AM
I may have found the culprit: the rear bolt of the main pipe was missing. Let's see if the rivets last longer now...
Regarding the sound absorbing stuff inside the muffler, it's kinda flat...
- what material is it?
- are there instructions available on how to stuff the silencer?
Old 04-21-2018, 04:56 AM
RBrider's Avatar
You don't stuff it, you wrap it around the core of the silencer, then hold it in place with a little bit of tape. Then slide the core back inside the housing .
I got a repacking kit from Fly Racing for my FMF equiped XC 200. It was reasonably priced and had good instructions included.
Most of the suppliers of repacking kits are pretty much the same, probably. Just find something that's available in your area.
RB
Old 04-21-2018, 10:49 AM
dANbOT's Avatar
dANbOT dANbOT is offline
Aluminum rivets don't tend to last all that long on bike silencers, if that's what you used. Next time try stainless steel rivets.... much stronger!
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Muffler cross over Russhole Enduro Engine - 2 stroke 1 12-13-2017 07:04 AM
Used FMF Q Muffler mcnut Parts 2 12-03-2014 09:37 AM
2014 300 muffler - what to get and where to buy n_green Enduro Engine - 2 stroke 14 08-19-2014 04:04 PM
muffler options lonetree General Discussions & Announcements 21 03-22-2014 05:38 PM
EC200 Muffler iancp5 Enduro Engine - 2 stroke 4 02-08-2009 06:02 PM
