Clutch play
I noticed this play in the clutch I bought second hand from ebay. Im pretty sure this is because of the rubber things in the outer basket that are worn out but I wanted to double check. Also how much does this really matter since the play is small. Some say it needs new rubber things in the outer basket,
Some say the play is small and its no worry: Note: only outer basket has play, not small. Nut is torqued down to spec Edit: cant attach video from phone, will do later. Either way, clutch can go in and out (towards the clutch cover and back in). Around 1 mm |
Here is the attachment
https://cdn.discordapp.com/attachmen...8/IMG_4383.mp4 |
I don't know,but my first thought is that I don't like it. Is the complete basket moving in and out?
No, only outer basket. Though it is so small, I really cant see how it would affect anything
Clutch free play | Nicktamps | Enduro Engine - 2 stroke | 2 | 03-13-2020 01:17 PM |
fly wheel play? | jgasser | Enduro Engine - 2 stroke | 3 | 01-09-2015 01:25 PM |
Another play on my bike | Bones1999 | Pictures & Videos | 4 | 03-16-2014 01:29 AM |
2013 EC300 Clutch play | skidmarx | Enduro Engine - 2 stroke | 0 | 06-30-2013 07:56 PM |
Clutch Adjustment - 3mm of play? | Stef | Enduro Engine - 2 stroke | 1 | 05-22-2010 01:27 PM |
