NEED Help with starter
2018ec300 starter worked perfectly till about 75 hours and was still working perfectly until it hung engaged and burned up the relay/solenoid. I've put on a new starter motor, solenoid, and starter button. I can jumper across the solenoid and the starter turns fine but not even a click when I try a start with the button. That only leaves the diode module and the wiring. How do I check the diode and where can I get one?
The small red wire at the starter solenoid provides the 12v from the start button.
I would check that circuit next. |
e-starter kit! | Frie82 | "Wanted to Buy" & "Want To Trade" | 0 | 08-29-2017 02:03 PM |
15 starter set-up | pigpen966 | Enduro Electrical & Wiring | 5 | 10-02-2016 05:48 PM |
Can I add a starter? | Jeffm | Enduro Electrical & Wiring | 17 | 11-09-2013 07:23 PM |
starter jet....where and how? | mp5 | Enduro Intake/Carburetion - 2 stroke | 1 | 05-01-2013 09:13 AM |
starter on 450 ec | jenkitchen1006 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 05-21-2009 06:38 AM |
