Old 11-09-2010, 02:42 PM
stainlesscycle's Avatar
http://www.mikesxs.net/products-82.html#products
warning: i am not 100% sure these fit 36mm-38mm pwk. they do fit 32mm pwk. i know the float needle does not. at $3.00 it was worth the risk..
07 ec300
www.stainlesscycle.com
Old 11-09-2010, 03:13 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
Originally Posted by stainlesscycle View Post
i found out you cannot order a jet block gasket for a tmx. urrghh..
I made one out of a sheet of heavy paper. What a PITA. I had the right size o-ring in my bag of o-rings.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 11-09-2010, 03:14 PM
Ud_luz's Avatar
Originally Posted by moto9 View Post
I tried to find the jet block o ring in a exploded view of the carb, but it's not shown ???
Let me know
Thanks !!!
There's a thread around here with pictures of everything but I couldn't find it. It's very obvious how things are put together when you take it apart.
Old 11-10-2010, 12:04 AM
moto9's Avatar
moto9 moto9 is offline
Good find !!!
I asked my bud to take his carb off and drop it off so I could take the jet block out and check it.
We were talking about this the other day...and because he's a beginner and new to the sport he didn't know that his bike was running like crap...he thought that was just how they are.
So, he's been riding the bike like this for almost 2 years, none of us knew until I took his bike for a good spin....it runs like s*#t.
So, I am on a mission to get it straightened out.
When I ran across your post, I thought that sounds just like the issue my buddy is having.
We'll see
In any case, thanks for posting it !!!
Old 11-10-2010, 09:01 AM
GMP's Avatar
GMP GMP is offline
Could you use Permatex or Yamabond in place of a gasket or is it too critical? orings are easy to source.
Old 11-10-2010, 09:59 AM
it's pretty critical, there are a lot of tiny passages....
07 ec300
Old 11-10-2010, 11:33 AM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
If you even touch the idle air screw .......
This might be totally non applicable, BUT I have noticed that when I adjust the idle air screw, it effects the spark plug. Sometimes it just fouls it out and the bike dies. Sometimes, what is even worse then a dead bike, is it starts running very erratic and strange, almost to the point you think there are some major issues.
Again, dont know if this helps, but thought it might.
gasgasdreamer
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 11-11-2010, 09:35 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Another thought.... Is your idle adjustment screw the plastic one or a brass one?
I had the plastic idle screw get hammered flat on one side from the slide being
dropped on it over time. Or maybe someone in camp kept snapping the throttle
when I was not looking....?!?!??
The bike would barely idle. If you turn the screw maybe 1/4 turn it would rev up
big time. Keep turning for a full turn and it would barely idle again.
I replaced the screw and problem fixed.
Worth the 5 min. to check.
Jeff
Old 11-11-2010, 06:39 PM
Ud_luz's Avatar
Where did you get a brass screw?
Old 11-12-2010, 09:27 AM
Hmmmm... I think I replaced it with another plastic one, but, I can't
remember for sure... It has been a few years since this happened.
I think a brass one may be available from Sudco or maybe as an
OEM part from another bike that uses the Keihein carb. I think my
KDX200 uses the same slide screw..?!?!?? I'd have the pull them both
to be sure.
Jeff
How to set float level. Revisited. gasgasman Enduro Intake/Carburetion - 2 stroke 48 11-10-2018 05:11 AM
Help 04 ec300 wont idle nmhinton Enduro Intake/Carburetion - 2 stroke 18 08-31-2011 10:51 AM
Rear wheel spacers revisited. Ud_luz Enduro Chassis & Body 9 09-13-2010 08:01 PM
can,t get idle up geno Enduro Intake/Carburetion - 2 stroke 1 04-18-2010 08:49 PM
2001 EC300 won't idle - can't get jetting right bexi Enduro Intake/Carburetion - 2 stroke 16 03-04-2010 10:30 PM
